Old 06-13-2015, 07:24 AM   #1
dloggins's Avatar
2010 30' Flying Cloud
Winterville , Georgia
A/C musty smell
We recently bought a 2010 Flying Cloud 31 with 2 A/C's. The A/C in the living area smells old and musty (like a wet crawl space) immediately when it comes on each time. I have taken it apart from the inside and there is no water in the tray, it's draining properly, cleaned the filters, wiped the interior shroud down. Has anyone else had this problem? My husband is going to check the outside, but i just thought I would see if I'm missing something.
Amy
3_happycampers
2010 Flying Cloud 30
2014 Ram 2500 6.7L
dloggins is offline   Reply With Quote
Old 06-13-2015, 07:43 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcome!
Open all windows, door, vent.
Remove filters, turn on fan, spray Lysol into the intake/return air.. Try to "dampen" the coils. Leave trailer for a minute. Do not remain inside.
Repeat at least 3 times.
Clean filters.. Dose with Lysol dry, repeat..
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-13-2015, 07:46 AM   #3
dloggins's Avatar
Ok, Thanks. I'm going to try that.
3_happycampers
2014 Ram 2500 6.7L
Old 06-13-2015, 08:09 AM   #4
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I would suggest also to get a can of AC coil cleaner. Get on the roof (using crawl board straddling rivet lines) and remove the shroud on the AC unit (4 screws) and spray the radiator-look-part liberally. The Lysol thing works well too for the air path.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
How do I eliminate the musty mouse smell?? mrrealtor General Interior Topics 30 04-16-2015 04:00 PM
Help with musty smell shelleysnyde Airstream Trailer Forums 28 02-20-2015 08:32 AM
Old Musty Smell rebelstand General Interior Topics 29 07-08-2011 04:51 PM
