Old 05-13-2004, 07:38 PM   #1
A/C location and aluminum covered unit?
Does anyone have a drawing of where the A/C should go on a '61 Safari? Also, someone tell me which unit to get and does any of these new units have a matching aluminum cover?
Thanks.
Marlboro Mafia is offline   Reply With Quote
Old 05-13-2004, 07:48 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
You are going to need to call Airstream or Inland RV for the placement. In most units a hole will need to be cut in the roof. In your unit there will not be an AC prewire, or a drain tube, so you will need to factor that in as well.
There is not a model that comes with an aluminum cover that I am aware of. One of the things you want to consider is AC unit height. The Duo Therm Penguin seems to be the choice for the low profile while maintaining a 13,500 BTU rating. It also has a 2 piece cover so you could paint the top silver if you wanted
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Spare Tires Marv Tires 6 01-20-2004 08:59 AM
Brushed aluminum? 69Ambassador Ribs, Skins & Rivets 7 10-21-2003 04:15 PM
