Old 07-26-2010, 09:31 PM   #1
Benvenito
1965 26' Overlander
Chatfield , Minnesota
Images: 8
Smile A/C just stopped on '65 Overlander
Ended up having two problems this weekend with the
Airstream at the inlaw's. But it kept me away from the
reletics, so~
Saturday night I blew a fuse (20 amp?) and lost all lights
except for the ones that ran off the battery. The A/C still
worked off battery power.
Sunday morning bought new fuse at hardware store, installed
it, all is well again.
Sunday night I arrive back at home. Set the Airstream up and
crank up the A/C. Works at first, but I come out 5 minutes later
and it's not doing anything. No fan, no condenser, no clicks,
nada. Checked breakers, they seem fine. Checked all 3 fuses in
voltage box thingy by water heater, they seem fine. Checked the
two fuses on the panel by the battery, they seem fine.
Also, I have what appears to be an aftermarket battery life tester
above where the breaker box is. It tells you how the battery is~
low, charging, charged,etc. It seems to not be working now either.
And I know if worked on Saturday.
Things I've done: replaced battery and made sure it was all charged
up. I've pulled out the toggel switch on the actual A/C unit, and
tested the wires to see if I have power to the switch--I do not have
power at the switch.
Any ideas what's up? Need new thermostat? Wiring problem?
Can I power it with a hot positive at the switch and get it going?
HELP! It's hot in Minnesota! THANKS!
Ben Volker
Chatfield, MN
"Ask not what your Airstream can do for you,
but what you can do for your Airstream."
[apologies to JFK]
"It's not the destination, but the journey."
Benvenito is offline   Reply With Quote
Old 07-26-2010, 09:36 PM   #2
reletics, so~
The original Armstrong TAC-110 air conditioner, does not in any way operate on 12 volts DC.
It will run fine, unless something is wrong with it, without a battery in the trailer.
Old 07-27-2010, 10:55 AM   #3
Benvenito
1965 26' Overlander
Images: 8
'65 Airstream A/C & 110 outlet fuse problems?
I've discovered that along with my A/C unit, I have
no juice at all my 110 outlets on the Airstream. I've
checked breakers and the 3 fuses in the Uni-Volt box.
And I've checked the 2 - 40 amp fuses on the low voltage
panel. Not finding anything wrong. Factory fan in roof works,
radio works, lights work. What am I missing? Thanks!
Ben Volker
Chatfield, MN
[apologies to JFK]
Old 07-27-2010, 11:00 AM   #4
Shut the city power breakers "OFF" and then flip them back "ON".
Then post what happened.
Old 07-27-2010, 05:38 PM   #5
Benvenito
1965 26' Overlander
Images: 8
It's official: I'm an idiot.
I went out and switched the breakers, and guess what I
discovered? I followed my extension cord all the way back
to my garage, and I discovered that I forgot to plug in my
extension cord when I set the camper up on Sunday. Ughhh.
Three days of troubleshooting for that! Well, at least now
I know my Airstream's electrical system a whole lot better!
Thanks so much, Andy. It's 94 degrees here, and now my
Overlander is pumping out ice cold A/C!! Kudos~
Ben Volker
Chatfield, MN
[apologies to JFK]
Old 07-27-2010, 05:40 PM   #6
That will cost you coffee, and at least one doughnut.
Oh, if all repairs could be so simple.
Old 07-27-2010, 07:04 PM   #7
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
It happens to the best of us
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-27-2010, 09:29 PM   #8
Gives us seniors something to laugh and talk about.
1965, air conditioning, overlander
air conditioner stopped working richinny Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-03-2010 06:10 AM
all stopped up nettepdx Fresh Water Systems 17 07-12-2008 09:45 AM
My Converter stopped converting thecatsandi Batteries, Univolts, Converters & Inverters 16 01-03-2008 10:05 AM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
