Old 03-27-2008, 07:44 PM   #29
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Thanks
Originally Posted by adonh
Here some additional picturers of my Spacer and the brass fitting to provide the drain line.
Don
Hi Don,
I really appreciate the photos! I got the AC on the roof and blowing cold air yesterday. Finished up and put the cover on today. First photos at http://www.airforums.com/forums/f427...tml#post540302. I will start a thread with more pictures tomorrow, perhaps. We’ll see how I feel after completing the cleanup. I will probably adapt your drain idea.
Vaughan
Old 03-27-2008, 08:05 PM   #30
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by lewster
I've installed 6 Carrier units in Airstreams and have never used a spacer. Not with the Dometics either. It is very simple to scribe the curve of the ceiling to the lower unit and cut the plastic with aviation snips. Fits perfectly. If you must, you can line the ceiling with 1/4" foam tape, but it rally isn't necessary unless you are getting evaporator freeze-up from too much cooled air directly feeding into the return.
Lew,
Are these the snips you refer to as aviation snips (tin snips where I grew up)..?
I bought a set of these on sale a few months ago (you know one of those "a man might need these sometime" purchases).
Old 03-28-2008, 05:41 AM   #31
lewster's Avatar
Naples, FL , Hood River, OR
Yup! Them's The Ones!!!!!!!!!!!!!
Old 03-28-2008, 07:29 AM   #32
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
[quote=vswingfield]Hi Don,
I really appreciate the photos! I got the AC on the roof and blowing cold air yesterday. Finished up and put the cover on today. quote]
The two-tone blue cover with pinstrpies looks great.
Don
adonh is offline   Reply With Quote
Old 03-28-2008, 10:31 AM   #33
1983 34' Excella
1967 24' Tradewind
Images: 32
Rivet Thanks!
Originally Posted by vswingfield
Hi Don,
Don
I will have to admit that when the compressor heated the cover up, the pinstripe tape came up over that area where it was stretched tight making the curve from side-to-side to front-to-rear. I was able to press it back down, but the curve isn’t nearly as graceful as original. It’s in the middle of the top, so you would really have to work hard (get up on the roof) to see it, so I didn’t stress out about it.
Vaughan
Old 04-02-2008, 06:52 AM   #34
1994 30' Excella
1973 25' Tradewind
wilmington , North Carolina
twin ac's
Just wondering, my 30 excella has twin ac's , I noticed most units have one, one is the original heatstrip type penguin and the other is straight ac. Is this a factory option or was the second one added? Also if necessary could you even run 2 on 30 amp power?
sluggo is offline   Reply With Quote
Old 04-02-2008, 02:35 PM   #35
lewster's Avatar
Don't know if it was an option.......but you will NOT be able to run both on 30 amp service. If your trailer does not have 50 map wiring and unmbilical, perhaps you might like to upgrade to 50 amp service to allow 2 units to run together.
It's not really that difficult!
Laminate Installation Question The Flintstones Floor Finishes 3 07-05-2007 07:56 AM
Inverter installation question Streamin 65 Batteries, Univolts, Converters & Inverters 13 06-07-2006 08:28 PM
1959 Tradewind floor installation question gtr Repairing/Replacing Floor &/or Frame 18 12-01-2004 10:05 AM
A/C installation and a question about the drip pan. Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-03-2004 07:56 AM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 06:58 PM
