Old 02-06-2010, 11:07 AM   #1
R n B
King O D Road's Avatar
1965 17' Caravel
1961 24' Tradewind
Ephrata , Washington
A/C installation
After talking to Andy @ Inland RV and getting the correct location for the A/C unit for our 65 Caravel, I opened up the ceiling and the wiring was right where he said it would be. Now I have the longitudinal stringers to install and the cross rib section etc.for the 14in. square hole. Also some wiring will have to be rerouted to clear the new stringers.
King O D Road is offline   Reply With Quote
Old 02-06-2010, 11:34 AM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
COOl
ArtStream is offline   Reply With Quote
Old 02-06-2010, 11:58 AM   #3
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
What brand AC unit will you be using? Do you need a drain line and if so how will you run it? Im interested in seeing what you do. I will be doing this myself someday
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-06-2010, 12:27 PM   #4
No need to reroute the wiring.
Drill a hole in the stringer, install a grommet, feed the wire thru the grommet, and it's done.
Old 02-06-2010, 12:28 PM   #5
drain line
A drain line for what "exact" year and length trailer??
Old 02-06-2010, 02:12 PM   #6
BradS's Avatar
1957 26' Overlander
Images: 14
I am wondering if a drain line is needed. Some day I want to add an AC unit ( possibly) to a trailer I will soon be working on. If the inside skins come off in the rebuild I would just add a drain line in case I ever decide to add an AC
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-06-2010, 02:13 PM   #7
R n B
1965 17' Caravel
1961 24' Tradewind
You are right Andy. Except the water pump wire that goes to the switch next to the kitchen window did not have enough slack in it to move it from the center of the 14X14 hole. I had to disconnect it from the switch and pull a cord back out and route it around the opening and back to the switch. I do not plan on putting in a drain line. The A/c that I put on my other trailer does not make enough condensate to run down the trailer side
Old 02-06-2010, 03:37 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
no drain line
Big mistake. If you come to a hot humid area...or sell it to someone there....You will have a mess. Ruins a polish job too. It only takes a second to put in a drain line...even if you don't use it yourself...now.
Old 02-06-2010, 05:00 PM   #9
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
I agree with Melody- if you ever head south (like TN) condensate will pour out. I would just do it while the skins are off.
My restoration photos on Picassa:
1967 Caravel
modarch is offline   Reply With Quote
Old 02-06-2010, 05:37 PM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Originally Posted by Melody Ranch View Post
....... Ruins a polish job too.
Yep, it sure did a job on mine. I have the new AC in the Trade Wind, I haven't put in the drain for mine yet but because the inner skins are in I don't have the ability to run the drain between the skins. So, I will be doing the tube through the cabinet and down through the wheel well trick. Put one in now while you have the chance.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-06-2010, 05:38 PM   #11
You are right Andy. I do not plan on putting in a drain line. The A/c that I put on my other trailer does not make enough condensate to run down the trailer side
We all make mistakes with some of our decisions in life.
If you don't put a drain line in, which is easy and simple to do, you will "WIN" a "BLUE RIBBON" for that mistake, guaranteed.
It doesn't matter what the other AC does, or doesn't do.
And if you ever went south, you will wish you never heard of the words "drain line".
Old 02-06-2010, 06:03 PM   #12
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Andy,I thought you said the Carrier unit did not need a drain?? Dave
easyride is offline   Reply With Quote
Old 02-06-2010, 06:08 PM   #13
That's correct.
But, I have no idea what King O D road may install.
Probably not a Carrier, since they quit making them.
Old 02-06-2010, 06:10 PM   #14
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
i think i read in 1 of my trade mags that carrier is backing out of the rv bussiness ?
crestonrv is offline   Reply With Quote
Converter Installation on a 63 1963tradewin Batteries, Univolts, Converters & Inverters 2 08-11-2008 03:46 PM
Maxxfan Installation willyd Roof Vents, Skylights & Fans 3 08-02-2008 05:13 PM
A/C installation chuman70 Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-05-2007 04:24 PM
Floor installation wohtex Repairing/Replacing Floor &/or Frame 4 04-15-2006 11:09 AM
a/c installation joecj76 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-27-2003 09:29 PM
