Old 12-22-2015, 06:16 PM   #1
1970 23' Safari
1977 Argosy 22
Napoleon , North Dakota
A/C installation???
I want to install an air conditioner in my 1970 23 foot AS Safari LY. Does anyone know if the wiring was installed at the factory or will I have to pull wire from the breaker box? I haven't purchased an A/C unit yet so am reluctant start removing the interior ceiling vent trim. Just thought I could get a few hints on this upgrade before I start.
Thanks, Bob
ab0wu is offline   Reply With Quote
Old 12-22-2015, 09:01 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
FWIW, Everything I have READ says they are prewired.
Brevi tempore!
Old 02-21-2016, 07:05 PM   #3
1970 23' Safari
1977 Argosy 22
Thank you. I'm just about to open the vent housing and look see. I sure hope you are right. You probably are.
Thanks again,
Old 02-21-2016, 07:51 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks again,
This is a link to the manual for your trailer. It has the wiring diagram showing the prewired circuit for the AC unit.
http://www.airstream.com/wp-content/...0110i.arc_.pdf
Alan
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
installation of shocks TCP4 Shocks 1 05-02-2002 04:45 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
