Old 05-02-2014, 07:42 AM   #1
1969 25' Tradewind
Ely , Minnesota
A/C Gasket install: To seal or not to seal?
Finally got my new Atwood AC in the mail the other day. After going through all the parts I am a bit perplexed regarding the foam seal. The instructions say to stick it to the roof and not the unit when installing (one side is a bit sticky). It doesn't say anything regarding adding extra sealant. Planning on sticking the gasket to the unit and laying down a thick bead of Vulkem on the AS skin around the hole.
What is everyone's opinion on this matter? I have read threads that say you don't need anything else and others that have used putty tape. If I use something like Vulkem or Tempro with this eat into the foam gasket? I like things easy but will put in the work to make things right.
seismicfish is offline   Reply With Quote
Old 05-02-2014, 10:02 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I installed a Penguin on my trailer. It already had the foam gasket securely glued to the bottom of the AC right out of the box. The directions did not specify that any sealant/adhesive should be used on the top of the trailer, so I attached it dry. It has been there for about a year now, through some heavy storms and hasn't leaked.
good luck!
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
'02 Safari Door Gasket Install Help Needed Ridgerunner3 Exterior Storage Compartments & Access Doors 4 10-10-2011 06:37 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
A/C seal/gasket rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-09-2006 10:36 AM
Window Gasket/Seal - Help! Herm and Debby Windows & Screens 13 07-21-2003 01:54 PM
