Old 06-06-2006, 09:35 PM   #1
cameront120's Avatar
1972 25' Tradewind
A/C for '72 Tradewind
My Tradewind wasn't equipped with an air conditioning unit. What would be involved in adding one? Were they pre-wired to accept an a/c, or would a new circuit need to be added? Does anyone have experience in this? What are my options for manufacturers. I'm familiar withCarrier as a brand, are there others I should consider? Thanks in advance for any help!
North Vancouver, BC
Old 06-07-2006, 06:57 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
It has to be AC-ready! One way to tell is find the drain line. It ought to be inside a wheel well--you'll just see the end of a semi-hard black plastic tube about the diameter of your finger. I've seen a post somewhere that said the 115V line is also installed and capped at the pre-planned AC location, inside the roof.
I think you have two big problems. First, unless someone knows exactly where the AC was to be located, you'll have to guess. Second, since you've never had AC, you don't have the "plate" installed that was designed to provide a flat spot and to carry the load. The modern gaskets for ACs are pretty thick, like 1-1/2", so the flat spot may not be that big a deal.
Even with the plate installed, I found the structure to be woefully short on support. You can remedy this by installing wood spacers between the inner and out skins around the perimeter of the 14" square hole needed to install an AC or a vent. Once they are secured, you'll be amazed at the monocoque strength of that area--you can do a pullup (remember those?) without deflecting the skins.
see my AC replacement at http://www.airforums.com/forum...tos-20568.html
The old plate is clearly visible. It provided not only the mechanical interface for the AC, but also was tied in to the cover. Modern units incorporate the cover with the unit itself, so those outer rails are not needed. I cut most of them off as best I could and bent the remaining ones down.
You can see I removed the flimsy sheet metal spacers that really only kept the insulation and wires from getting in the way--they didn't provide much strength. BTW, after you cut the access hole, if you can't find the pre-installed 115V line, you will find all the 115V lines going to the receptacles running along the ceiling and just offset about 9" to one side (the 12VDC wires are offset on the other side). You ought to be able to tap into them easily.
Old 06-07-2006, 07:59 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The drain line on my 75 is just in front of the street side tires.
Richard
Old 06-07-2006, 08:03 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
somebody knows. I believe you can get that information from any dealer, or the factory itself. the locations of the factory installed wiring for optional equipment is published in the service manuals.
anyway, in the 70's, all models were pre-wired and plumbed for a/c.
I suspect that this plate may have been part of the original a/c...not the trailer itself. Mine has no such "plate". wooden supports were used around the outside of the hole, though.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-07-2006, 08:12 AM   #5
1972 25' Tradewind
Thanks for the very helpful feedback! First order of business this evening will be to check the wheel wells for a drain!
North Vancouver, BC
Old 06-07-2006, 09:19 AM   #6
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
If you get a carrier, you don't need any plate. It pretty much just drops into a hole, either an old vent location or a new one you cut. You probably want to reinforce the opening with either u-channel aluminum or wood. Also search for posts by pattersontoo on this topic, he has some nice how-to's on it.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 06-07-2006, 06:56 PM   #7
1972 25' Tradewind
Thanks John, I'll do a little searching for those posts!
North Vancouver, BC
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
