Old 10-23-2014, 12:55 PM   #1
1964 19' Globetrotter
Fall Branch , Tennessee
A/C for 1964 Globetrotter
Can a roof mounted a/c be installed on my 64 Globetrotter as it is, without having to reinforce the roof. If so, does it have to go where the fan is or can it be installed in place of the skylight?
Rick0824 is offline   Reply With Quote
Old 10-23-2014, 03:16 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
The '64 has a similar vent layout as my Globetrotter '67 did. On the GT a Coleman unit was installed midships. I do not know if it had the roof reinforced. I recall seeing a video where someone was using 2X2 wood to fill the space between the inner and outer skins under the A/C on a '60's rig.
I added an A/C unit to the '72 Tradewind between the center and rear vents and did have to reinforce the roof with aluminum channel.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 10-23-2014, 05:45 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your 64 may be pre-wired for an air conditioner. Look for a black, un-attached romex 2 conductor wire close to your breaker box. Other Globetrotter experts may be able to confirm this.
It's a smaller trailer so you won't need the 15,000 btu size.
David
1964, 1964 globetrotter
1964 Streamline Duke :: 1964 Streamline Duke rjdelbueno Airstream Registry Discussions 0 06-18-2012 11:30 AM
1964 Globe Trotter :: 1964 Airstream Globe Trotter Wilcu Airstream Registry Discussions 1 03-11-2012 04:35 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
