Old 05-25-2006, 12:27 PM   #1
1965 26' Overlander
Acworth , Georgia
A/C Fan wiring
Ok,
Another question. Am I reading the wiring diagram right?
Seems like the 125VAC does to transformer, and 14VAC goes down to thermastat. Line returns to dummy side of transformer, where it meets line to relay. Other side of relay does back to 2nd pole on tansformer. The 14VAC throws the relay, allowing 125VAC power to fan and condenser. Correct?
Is fan supposed to be single or 2 speed?
PhilMateo is offline   Reply With Quote
Old 05-25-2006, 03:06 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Phil,
It depends on your unit. Every A/C manufacturer uses a different current path for their fan motors with different specs on the start and run capacitors.
Can you post a wiring diagram?
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 08:52 PM
a/c theromstat sudden impact Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-09-2002 07:04 PM
