Old 02-22-2014, 06:15 AM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
A/C fan runs slowly
The hottest day of last summer I was running my air conditioner all day full blast when suddenly it started to run real slow and just drizzle cool air. Not wanting to call some repairman to tromp around on my Tradewind's roof, I bought a used window unit for $70 and decided to fix it myself when the weather cooled off.
Fast forward to cool weather (2/21/2014) and I climb gently up top to see what I can do. Removing the cover to expose the condenser, fan, and wiring took a screwdriver on the four screws. To test the unit I turned it on and noticed the fan was turning, just very slowly.
That's where I am now. Does anyone remember having a similar problem? Before I go further I thought I'd check Airforums to see if I can get an opinion or two.
terrencecolp is offline   Reply With Quote
Old 02-22-2014, 10:29 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If I had to guess, I'd say the brushes on the fan motor are worn down to a nub, so you're not getting good contact for electrical power to the motor's rotor. Either that or the motor might need to be rewound. Or both.
That's assuming that the air conditioner is as old as the trailer, and not a late-model replacement.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-22-2014, 05:33 PM   #3
1976 25' Tradewind
Tulsa , Oklahoma
no go
It is original to the trailer. It was just so strange the way it went out. One minute it's working perfectly, the next it starts running slowly. I know it spins freely because I tried that thinking bad bearing. It never gave me a hint at going bad. It was such a great unit and blew ice cold.
Old 02-22-2014, 07:29 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I have never seen an A/C blower or fan motor with brushes. They are invariably either shaded pole, or on somewhat larger units, permanent split capacitor.
Typically it's bearing failure but it doesn't really matter much because the motors aren't worth servicing. Just find a replacement motor. If you search threads you'll find sources and some part numbers.
Old 02-22-2014, 07:48 PM   #5
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I had an AC lock up from a mud daubers nest but that doesn't sound like your problem. If it's an Armstrong unit I hear it's worth fixing. Good luck Mike
desertair27 is offline   Reply With Quote
Old 02-22-2014, 07:55 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A/C fan runs slowly
The fan shaft might just be tight in the bushings, may just need a good cleaning and lubrication.
Does the squirrel cage turn freely?
Old 02-22-2014, 07:55 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Plus 1 on the Armstrong unit..
Old 02-22-2014, 09:32 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It may be running on the start winding. And not kicking into the run mode.
It's been a while since I looked at the schematic. Perhaps the fan does not have a start and run winding like the compressor motor. But I would check the drawing.
Old 02-22-2014, 10:26 PM   #9
Ottawa , ON
Don't those Armstrong AC units have both start and run caps? Cheap to replace, not hard to do either.
Couldn't hurt...
Old 02-24-2014, 09:01 AM   #10
1976 25' Tradewind
Tulsa , Oklahoma
rookie a/c man
Being no electrician, is there a way to straight wire just the mother to 110 (bypassing all starters, etc.)? The motor has no signs of burning, doesn't smell cooked. The fan free wheels.
Old 02-24-2014, 09:32 AM   #11
Absolutely not.
Old 02-24-2014, 12:25 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does your unit have multiple fan speeds? Either by a selector switch or push buttons. Try changing speeds and see what happens.
Does it run slow in all speeds?
If so, I would replace the capacitor.
Unlike the compressor there is no "start" and "run" relay(s) on the fan.
Just a single capacitor, which causes enough of a phase shift to get the motor to start rotating. Once it starts to rotate, it should come up to the selected speed.
Old 02-24-2014, 07:03 PM   #13
1976 25' Tradewind
Tulsa , Oklahoma
The fan runs the same on all three speeds. Is the capacitor that cylindrical black thing about 3" long? With two wires on top?
Old 02-24-2014, 10:16 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes. There should be 3 total. 2 for the compressor and 1 for the fan.
Make sure the power is disconnected and the capacitor is discharged.
Otherwise, you may get shocked.
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Best way to install Fantastic Fan dcole Roof Vents, Skylights & Fans 3 10-01-2011 08:31 PM
1968 A/C not spinning fans on startup? hayduke Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-05-2011 09:21 PM
2008 Bambi fan for refrigerator mikeandsusan Refrigerators 5 08-28-2011 10:40 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
