Old 05-27-2014, 04:31 PM   #15
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Would like to have the option of complete shutdown, but ours are 3 speed always on, found once area is cool it is doable to change to low, alternative is to run the a/c not where we are, living area or bedroom, when one can handle it. That only happens when we are in a shady spot, full sun and it has to run, to keep up and move air for comfort.
Old 10-09-2016, 06:00 PM   #16
rbg46's Avatar
2016 19' Flying Cloud
Gainesville , Florida
Found this thread this afternoon while researching the "fan doesn't turn off" issue for our 2016 FC 19. Until early this morning the fan would shut off when the compressor cycled off. We have the Dometic with ceiling ducts. the remote thermostat is set on Auto, but the same thing happens in a/c mode.
Guess it'll be off to the dealer Monday since we're still under warranty.
rbg46 is offline   Reply With Quote
Old 10-15-2016, 08:01 PM   #17
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
My 97 Landyacht has the two original Duo-Therm Penguin units made by Dometic. I have a single wall t-stat that controls both and it has auto mode which makes them cycle off-on as needed.
Mike1997 is offline   Reply With Quote
Old 03-01-2017, 07:36 AM   #18
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
I have the same issue.... what was the fix?
Thanks Mark
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
A/C fan runs slowly terrencecolp Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-27-2014 09:12 PM
Doh, Only two wires but the fan runs backwards! GREENovaters Electrical - Systems, Generators, Batteries & Solar 8 07-18-2011 05:12 PM
'76 Sovereign Water Pump Runs ALL THE TIME Hummer Water Heaters, Filters & Pumps 4 08-17-2010 03:08 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 05:37 PM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 05:25 AM
