Old 01-01-2010, 12:27 PM   #1
Airhouse's Avatar
1991 34' Limited
White Pigeon , Michigan
A/C Drips on New Years Day 2010
Hi Streamers; Happy 2010. About noon today in mid-florida we had a short,but , hard rain and the most wind we've had lately, that came directly from the door side. We winter in a early 90s 34ft limited and for the first time ever we got dripping right by the A/C coming at the seam of the two ceiling panals a couple inches away from the inside A/C cover. Could the wind shift the unit enough to let water get past the seal? Where else has the water likely gone? The unit is the Duo-therm,Penguin. Is there a pan? Any help or guesses as to what's happening will be much appreciated. Thanks
Airhouse is offline   Reply With Quote
Old 01-01-2010, 01:20 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
It would have to be much more wind than we experienced in that storm, here in Inverness. If the unit is bolted down right and your unit is still upright I doubt it was the cause, otherwise with highway travel, every time you are at highway speed and raining you would drip.
Old 01-01-2010, 01:50 PM   #3
Airhouse's Avatar
1991 34' Limited
Hi DaveFL; We did have some really gusty winds a few hours ago, that said I see what you mean by getting the same thing when on the highway. maybe my A/C seal is getting tired!!! Can't think of what else would start leakage in that area. Thanks anyway. Bud
Old 01-01-2010, 03:11 PM   #4
Lothlorian's Avatar
Loganville , Georgia
I was just at the RV service center. Apalachee in Winder Ga. Great guys.
I asked how much it would cost to put a new gasket and seal because my AC is leaking water when it rains. I was told before I do a replacement take the inside cover off the AC and tighten the bolts holding the AC down. I was told that some times over years they will become loose and water will leak. I did what they told me and found out my bolts were very loose. Now I have to wait for a heavy rain to see if I corrected the problem.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 01-01-2010, 05:06 PM   #5
Airhouse's Avatar
1991 34' Limited
Hey Brian; thanks for the getback-- that's an idea the sounds great. going to try it. I'll let you know it it works. Ok thanks again. Bud
Old 01-17-2010, 04:30 PM   #6
Airhouse's Avatar
1991 34' Limited
Hey LOTHLORIAN; Your info was right-on. Took a spell, but I tightened the A/C mount bolts, they were loose, and waited for wind and rain. today we had both, and all was dry. thank you for taking the time and passing on a fix to made the job easier. The forums are great.
Shark Bite drips! radiodial Plumbing - Systems & Fixtures 13 11-16-2009 07:50 AM
Mystery Water Drips 73Overlander 1973 Overlander 6 09-11-2008 08:14 PM
City water pop-off valve? (drips included) empresley Fresh Water Systems 15 02-10-2008 06:12 PM
Beatrice Years - Years and Models to Avoid? AndyPenny Buyer Guidelines 7 10-15-2007 11:04 AM
Tub Faucet Drips niftypkg Sinks, Showers & Toilets 9 12-19-2005 04:48 PM
