Old 02-23-2007, 10:01 AM   #1
moman
2004 25' Safari
stuart , Florida
A/c drip-pan crack 25' Safari
A/C drip-pan replacement.
Help please!
Thank you
moman is offline   Reply With Quote
Old 02-23-2007, 11:47 AM   #2
Images: 59
Order from nearest AS dealer, part #961270, $70.
You can have the dealer ship it direct to your home if not in stock.
markdoane is online now   Reply With Quote
Old 02-25-2007, 07:54 AM   #3
moman
2004 25' Safari
stuart , Florida
Drip pan
Thanks for the info! I wanted to try and patch the drip-pan first. The problem is, how do I get at it? I have an 04 Safari, and when I take off the inside cowling I can see the edge of the pan with the hose, but most of the pan is covered with a plate. Is it safe to unbolt the plate? There is no way to get at it topside.
Any help would be great. I already talked to the Dometic factory and Airstream, they couldn't help much.
Thanks again
Old 02-25-2007, 08:02 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It is a big hassle to get in to patch it, as much trouble as it is to get in and replace it. For the relatively small money involved, and the fact it is readily obtainable, I would recommend replacing it.
Old 02-25-2007, 08:10 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
That's pretty young for a drip pan to fail...any idea what happened?
Old 02-26-2007, 01:30 PM   #6
Moman, unless you can see the split from below, to repair or replace the tray you will need to lift the entire unit from the roof. Details of how to achieve this without a crane are here:
http://www.airforums.com/forum...ck+gasket+roof
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
New Colman A/C (HELP!!!!!!!) TheBigRedTruck Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-24-2002 10:14 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
Camping World - No A/C Pan? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 08:55 AM
