Old 05-30-2010, 01:52 PM   #1
judybug's Avatar
2004 25' Safari
san antonio , Texas
A/C Drip in 25' Safari
Our air conditioner is dripping water on the floor. Do I need a drain hose? How can I tell if there is already one there, but just stopped up? Is this a job for an Airstream dealer?
judybug is offline   Reply With Quote
Old 05-30-2010, 02:30 PM   #2
bobandcarla's Avatar
2005 25' Classic
Pelham , New Hampshire
If you remove the cover you can see the hose. My hose drains between the wheels on the street side. I could see that it was draining but I had water on the floor also. Unless your handy it might be a job for the dealer. I had a crack in the pan that holds the water. I placed an aluminum pan under it and it catches any drips and then they evaporate. We spend time in Florida and use the AC when it's hot and I have no more drips.
Good luck
Bob & Carla
05 classic 25'
WBCCI # 1836
bobandcarla is offline   Reply With Quote
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
A/c drip-pan crack 25' Safari moman Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-26-2007 01:30 PM
Drip, Drip and Crack jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-06-2006 08:17 AM
25' Safari Devoman Our Community 13 02-11-2006 08:21 PM
Safari 25' ss & CCD 25' - odor issues? darkStar Waste Systems, Tanks & Totes 15 09-29-2003 01:28 PM
