Old 07-21-2018, 07:17 AM   #1
Wishing's Avatar
2014 27' FB International
Arlington , Virginia
A/C draining water inside
This problem started a year ago after not having it happen for the first three years weve owned the trailer...the A/C drains the condensation inside the trailer. And weve camped every year in particularly high humid environments such as in FL, but the draining inside hadnt been an issue until last summer. At first I thought the drain pans or the lines themselves may have been blocked, but I removed the unit and the pans were clean and though the lines drained the water I poured into them to check, I still used an air compressor to make sure they were clear of any blockages/buildup. I took the trailer to Jackson Center and they replaced the pans and added some wrapping(?) based upon advice from Dometic. Well, were back in FL and its happening again which is frustrating, but does anyone have any thoughts on what I might be able to do to fix this?
Wishing is offline   Reply With Quote
Old 07-21-2018, 07:56 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
When this is happening drop the shroud or filter frame from the ceiling and check the face of the evaporator coils for ice. If the AC unit is low on charge it can cause the coils to freeze and depending on where that ice forms it may be blocking the drain right below the coil.
2004 Excursion 4x4
Old 07-21-2018, 09:00 PM   #3
rd tighe's Avatar
2007 25' International CCD FB
We are , Relaxed
Images: 12
We had that problem . Took cover off on the inside look for the leak. It was in tne condensation pan dryed it used E6000 problem fixed 4 years now.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' fb International Solar
2007 Dodge
rd tighe is offline   Reply With Quote
Old 08-02-2018, 11:15 AM   #4
Wishing's Avatar
Thanks to you all. We think we have a temporary fix by removing the little dark gray center tray and also the two filters and loosely putting the cover back on. Still leaks a few drops, but nothing like the big leaking before.
Old 08-02-2018, 11:33 AM   #5
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
FWIW - we recently had an issue with our a/c. While researching the problem we found several warnings not to use the a/c without the filters. Doing so will allow dust, dirt, etc to clog the grill fins and cause poor operation.
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Dont Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 08-06-2018, 11:28 AM   #6
Wishing's Avatar
Oh man-for now Ive decided Id rather deal with potentially cleaning the dust out and not have my comforter soaked, but will definitely consider myself forewarned.
AC Draining inside trailer John Geisen Furnaces, Heaters, Fireplaces & Air Conditioning 26 05-18-2017 05:59 PM
Air Conditioner Condensate Draining Inside Camper bigbuck1962 Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-14-2016 10:26 PM
Water draining from the belly pan Roadtoaster Belly Pans & Banana Wraps 5 06-24-2015 04:09 PM
draining water heater John Greenlee Winterizing, Storage, Carports & Covers 15 12-30-2005 03:04 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
