Old 04-22-2011, 05:04 PM   #1
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
A/C drain tube is kinked
The drain tube from the a/c unit, inside the camper roof to the outside wheel well area, is kinked as it makes a sharp turn.
Can anyone tell me by looking at the photo, if this is the correct
placement of this tube with that right angle.
Husband is not sure what to do at this point to correct it.
Can a new tube replace this one? and how would it follow the path to get outside? HELP..
He thinks this is a good spot to crack and then leak water inside our camper?
Janie Q
Janie Q is offline   Reply With Quote
Old 04-22-2011, 05:55 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
The photo is not exactly crystal clear, however, the main thing is determine whether or not there is any obstruction to flow of water in the existing tubing. As long as there is no "crud" in the tubing and that the condensate from the A/C can flow freely into the wheel well, then you have nothing to worry about. Good luck. (If there is no obstruction, then I would not "fix" it. In other words, If it ain't broke, don't fix it.)
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-22-2011, 06:39 PM   #3
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
I took it with my iphone.. I'll take a real camera in there tomorrow and stick my head in farther :/
Jane
Old 04-22-2011, 07:51 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Different A/C units connect at different spots. When we replaced ours it end up with a sharp curve that I was afraid would end up kinking. We cut the drain line and put a 90 degree elbow in the line to stop that from happening.
Tube Frame Debate crzycpa Repairing/Replacing Floor &/or Frame 9 07-05-2011 09:34 PM
No Drain Tube bwaysteve Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-18-2011 03:59 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 07:16 PM
Where do the roof A/Cs drain on 345 moeriv Classic Motorhomes 4 01-19-2011 08:20 AM
