I have a 77 airstream argosy 24, and the a/c on the roof has been replaced with a duo-therm. It drains all down the sides of the trailer when its running. is there a way or has anyone connected this unit to the internal drain before? Is this unit setup to do that, or will it all have to be custom?
guess I'll just have to fumble thru it and figure it out myself. probably need to pull the whole unit anyhow and fix the badly done patch from the po that caught the ac and ripped it off. it has a big screwed on patch with sealant tape around the edges. Think I will rivet and seal a new patch on so its more permanent.
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
The new Dometic I put on our 91 used plasic cups under each side of the pan that get piped together and tie into the existing in wall drain tube.
pretty mickey mouse really and the kit costs $70 .
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
