Old 07-02-2014, 02:52 PM   #1
jcain63's Avatar
1972 25' Tradewind
lancaster , California
A/C drain???
Hello, I have a 72 tradewind and I turned the A/C on and it works like a champ. However I noticed water coming down over the top of the trailer. Where is the drain and how can I fix/replace it without having to tear the whole interior apart. Any suggesting?
Flo is getting a make-over!
jcain63 is offline   Reply With Quote
Old 07-02-2014, 05:19 PM   #2
MissPearl's Avatar
1989 29' Excella
Pauline , South Carolina
If it is a Coleman then the drain is on the driver side within the ac unit. Remove the shroud. Pour some algaecide or bleach into the drain pan... You will be able to seeit.
MissPearl is offline   Reply With Quote
Old 07-02-2014, 05:20 PM   #3
MissPearl's Avatar
1989 29' Excella
The drain line is on the driver side just in front of the wheels. Hook your shop vac to it and suck out the good stuff.
Old 07-02-2014, 05:36 PM   #4
jcain63's Avatar
1972 25' Tradewind
I will, thanks for the help!
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 08:42 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
