Old 08-01-2006, 07:28 PM   #1
JimGolden's Avatar
1977 31' Excella 500
A/C Died Tonight
Howdy All,
I just read a great thread started by Rebel Beck, and I hope that I have the breaker problem and nothihng worse.
My air conditioner seems to have died tonight. My trailer was wet and I was running the a/c to dry it out. Not to mention that it was pushing 100 degrees here today.
I turned it on last night and it worked just fine. Got it plugged into a dedicated 30amp RV recepticle, plenty of juice. Like a deep freeze in there last night when I turned in for the night.
This morning, it was still chumming along just fine. I got home from work about 6:00pm tonight and the compressor wasn't running; only the fan.
I turned it off, then turned it back on. The compressor tried to kick on, stuttered a bit, then popped the breaker.
I reset the breakers, and nothing. Zip. NADA. She's dead as a mackeral.
Please tell me it's just the breakers are bad and not a fried compressor.
Any guesses? I'm not too shabby with a multimeter. What should I check?
Help!!!!!!!!
- Jim
JimGolden is offline   Reply With Quote
Old 08-01-2006, 10:24 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Jim,
You should first check to see if you are getting 120VAC to the unit. Remove the inside cover and you will see a junction box. First, with the breaker off (unless you want us to start calling you 'Sparkie' ), remove the cover and untwist the white and black wire nuts. Keeping them separate, turn the breaker on and see if you are getting voltage at this point. If yes, you have a problem with the unit.....if no, you have a problem at the breaker box OR the wires that are coming FROM the breaker box to the A/C unit. Also, make sure that all of the connections in the J-box are tight if voltage is present. You might have a bad breaker even though it seems to work.
To check this, remove the hot wire from the breaker and the breaker from the panel. Do a continuity test on the breaker to see if you are getting anything across it. If not....replace it and that should solve your problem. If you have voltage at the A/C junction box, we will have to look deeper.
You also might have fried the start capacitor and then possibly the run capacitor in the upper unit. They are located in the upper shroud next to each other so you have to get on the roof to remove that. They will look wierd, fried or bulging most of the time if they are bad. I'm not sure of what unit you have, but if you have a PTCR, that might be gone also. If you can read the micro farad spec on the capacitors, you have to disconnect all of the wires to check the readings, provided that your meter reads capacitance. You should also be certain that the caps are discharged FIRST!!! BTW, AC power should be OFF for this test!!!
Keep us posted on what you find.
Old 08-02-2006, 12:05 PM   #3
JimGolden's Avatar
Thanks Lew!
Lew, thanks for the advice. I'll get out the multimeter and do as you've said. Will report back when done.
thanks again!
- Jim
Old 08-02-2006, 01:09 PM   #4
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Jim,
When our breaker flips there is no noise. I hope for your sake it's not death to your a/c. But the way I think about our Airstream is use them till they die and then buy new.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 08-04-2006, 10:51 AM   #5
JimGolden's Avatar
I changed out three of the four breakers; all but the GFCI, and it seems to work fine now. I discoverd that pushing on the old breaker made it turn on and off. I'm hopeful that's all it was!!
- Jim
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 06:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
