Old 07-06-2011, 04:37 AM   #1
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
A/C Compressor won't cycle off
I finally installed a 30 amp dedicated circuit at the house to be able to run the original AC in the Trade Wind while at home. I have not run the AC a lot but yesterday I noticed a problem in that the compressor never cycles off. I can set the thermostat to 90 and the compressor still runs. The unit works great, but after about an hour the inside is freezing. Any ideas on what to check or replace would be appreciated. The unit does have a new fan motor so is has been worked on in the past.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-06-2011, 05:12 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The thermostat would be the first thing I would check.
Richard
Old 07-06-2011, 11:23 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Checked that first, unhooked the wire- no help
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-19-2011, 08:19 AM   #4
Darius K's Avatar
1988 32' Excella
Stockton , Missouri
Did you ever come up with the answer on this. Ive got the same issue. I am going to start testing capacitors but it would be nice if you had an exact place I should start . thanks.
Darius K is offline   Reply With Quote
Old 08-19-2011, 08:25 AM   #5
The contacts in the run relay, are burned together, so it doesn't matter what you do with the thermostat.
That is not uncommon.
Old 08-23-2011, 09:28 PM   #6
Darius K's Avatar
1988 32' Excella
Stockton , Missouri
Thank you yet Andy! I guess Ill get up there and get a part # and give you a call.
A/C Pops Breaker RichWoodward Furnaces, Heaters, Fireplaces & Air Conditioning 28 07-19-2011 05:57 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 05:59 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
