I have an 87 Excella. When you turn on the A/C the fan comes on, then the compressor tries to come on but won't. The low power light comes on. It is on a 30 amp outlet, and nothing else is running on this outlet. It is a Coleman A/C.
Try using a volt meter and check the voltage before turning it on. Should be around 115 to 120. Than check the voltage after you turn it on. If it drops below 110 than there is a power supply problem somewhere. Check all your connections to make sure they are sound and free of corrosion and are making good contact. I just discovered one of the prongs on the end of my cord coming from the breaker panel in the trailer was partially broken and was causing some voltage supply issues. It may not be the problem but it's a good start and it is always good to start with the simplest of things first because more often than not it ends up being something so simple that it never occured to you to even take it into consideration.
I will have my son check that next time he is over, Thanks
