Old 07-03-2013, 08:17 PM   #1
2012 25' Flying Cloud
Tualatin , Oregon
Angry A/C code E7...
2012 Cloud, FB with twin beds, etc...living in the Pacific NW, not much occasion to use the A/C on the west side of the Cascades. On our second trip to the East side of the Cascades its a bit warm here today and am attempting to use the air...it ran for a bit then shut off and is displaying code E7. Nothing in the owners materials indicate what this might mean...any thoughts??
Tried turning it off and letting it sit for an hour, but no luck...breakers are OK, all other functions in the trailer are fine...
Any input welcome as it will be a warm few days here just outside of Bend, OR.
Thanks in advance for your input!!
nagorider is offline   Reply With Quote
Old 07-03-2013, 09:02 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
E7 is a loss of all 120V AC power. This is likely caused by a tripped breaker. Turn the A/C breaker in the converter box completely off and then back on. The Error Codes are in your thermostat manual.
Al - K4GLU is offline   Reply With Quote
Old 07-03-2013, 09:07 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
For your convenience, here is a listing of the error codes for the Comfort Control II thermostat:
Error Code:
E1 Loss of communication between the CCC 2 thermostat and all system power module boards. System will shut down.
E1 Loss of communication between the CCC 2 thermostat and an individual system power module board. The LED will display error code EI and the zone number that lost communication. Any additional zones that loose communication will blink in addition to the current zone.
E2 Open circuit or out-of-range indoor temperature sensor. All heat , cool, and dehumidify operations will be locked out. Manual fan operation will continue.
E3 Shorted Indoor Temperature Sensor. All heat, cool, and dehumidify operation will be locked out. Manual fan operation will continue.
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat pump and dehumidification operation will be locked out. Air conditioner, furnace, heat strip and fan operation can continue to operate.
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification operation will be locked out. Heat pump, furnace, heat strip and fan operation can continue to operate but displays the last temperature set-point.
E6 Open circuit Humidity Sensor (Select Models). Air conditioner and dehumidification will be locked out. Heat pump, furnace heat strip and fan can continue to operate.
E7 Loss of 120 VAC power to all power module boards on the system. The system will shut down.
E8 Invalid zone configuration. The heat pump and heat strip DIP switches are both set to the ON position in one zone. Heat pump, heat strip, air conditioner, and dehumidify operation will be locked out in the affected zone.
E9 Invalid zone configuration. The dehumidifier DIP switch and either the heat pump or heat strip DIP switches are set to the ON position in one zone. Heat pump, heat strip, air conditioner, and dehumidify operation will be locked out in the affected zone.
Sometimes a breaker will look like it is in the operating position but is actually tripped. Be sure to flip the breaker lever to 'OFF' and then back to "ON' with the corresponding click.
Old 07-03-2013, 09:46 PM   #4
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Lewster you are the MAN! Time and time again you have provided invaluable information to those of us on this web-site. I for one appreciate being able to benefit from you knowledge base. Thank you from all of us.
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Old 07-03-2013, 09:57 PM   #5
Tualatin , Oregon
Thanks for all the input, but no luck so far...still getting the E7...checked power at the pedestal and turned all the breakers on/off a couple times...by touch and sight all the breakers are in the same position...fuses are all OK too...
Old 07-03-2013, 10:17 PM   #6
Tualatin , Oregon
Update...checked pedestal again...transferred power cord to rear power connector...no change...there is no power coming into the trailer...microwave is out, 120 volt outlets are dead, etc...thoughts??
Old 07-03-2013, 10:36 PM   #7
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
What are you plugged in to - check it. Sounds like loss of power to power outlet.
Silver Hawk is offline   Reply With Quote
Old 07-04-2013, 02:16 AM   #8
richinny's Avatar
2011 34' Classic
you're power transfer switch has possibly failed. have you checked the breakers in your trailer?
Ricky
Old 07-04-2013, 05:44 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Try resetting the gfci breaker. If that oesn't work, you may well have a bad transfer switch.
Old 07-04-2013, 07:26 AM   #10
lewster's Avatar
You need to get an actual reading AT the breaker box. Remove the outer cover of the breaker box and using a multimeter, check between the 120VAC 30 amp line coming in to main breaker and neutral. It should read in the vicinity of 120VAC.
If it does not, then there is no power coming into your breaker box. As stated above, if you have a transfer switch, it might be bad. It is not difficult to bypass it, but it must be done with the shore power unplugged.
Old 07-04-2013, 09:00 AM   #11
2012 27' FB Classic
yakima , Washington
Hello
We have a 2012 FB and had the same problem this winter with the refrigerator. Found a wire in the cluster plug behind the refer was not always making contact. Pushed it in like the others and have had no problems since.
Hope your issue is something simple like ours was.
Mike
Mike and Gloria is offline   Reply With Quote
Old 07-04-2013, 09:43 AM   #12
Tualatin , Oregon
thanks for all the input...here's the update...
Pedestal power is OK...also tried both the front and rear plugs...power is available...
Breakers have been switched on/off...all appear to be OK both by touch and visually...
GFI, on the bathroom wall, is also OK...but dead...(our GFI failed right out of the box when the trailer was new and was replaced)
All AC outlets, in and out, and appliances are dead, including the microwave...
Will grab a voltmeter and check the incoming power....
Again thanks to everyone for all the input...very much appreciated!!
Enjoy the 4th!!
Old 07-15-2013, 11:02 PM   #13
Tualatin , Oregon
The final answer...back from the Airstream dealer here in Portland...all is well...after a new transfer switch was installed!! It had tripped and failed in the off position, killing the power supply in the trailer. If it had not tripped/failed but stayed in the on position, we may have never known. Don't know why it tripped in the first place but all is well with thanks to the Airstream warranty and a creative dealer in finding the part locally in minimal time! Learned a lot...especially here!! We had multiple inquiries and suggestions on the morning of the 4th!! Lesson learned...always travel with our portable solar system to support the battery and also always carry a 50' extension cord. With those two items we were able to continue our 6 day trip instead of coming home defeated in 2!
Thanks again for all the input!!
Old 08-21-2016, 03:41 PM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I know this is an old thread but we just got the E7 message too. The AC would start, then kick in for real cold air and in about 5 seconds would shut itself off. It would wait about 5 minutes and try again, same result. I checked the power pedestal where my Progressive Industries 30a protector is plugged in. No error messages there. I turned off and on the AC breaker in the trailer. Same result. Finally, since this thread talked about the possibility of a faulty transfer switch, I plugged the 30a cable from the pedestal in to the front of the trailer where the gennys usually plug in. The AC works fine now. So I'm assuming I actually do have a bad transfer switch which we'll take care of after the next couple weeks of anniversary vacation ��
