Old 08-27-2010, 08:21 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A/C Ceiling Reinforcement
I'm at the CG (with lousy wireless signal) prepping for new AC install.
Have the interior off - the old unit is a Coleman Delta TX. It appears rather than do a permanent reinforcement - there is a plastic tray that is inserted into the exterior opening. On the bottom of the tray they riveted and vulkemed C channel as the reinforcement. I can't tell if the tray is attached to the rooftop unit.
Has anyone removed a Coleman and found this setup.
What did you reinforce with for the new unit and does anyone recall the thickness needed. I have someone coming out to help in the morning - so I may be able to have him pick up the needed reinforcement on the way out.
Pipe Frame stabilize/reinforcement Vintage One Repairing/Replacing Floor &/or Frame 1 07-05-2010 01:54 PM
Mercedes GL receiver reinforcement hartusi Hitches, Couplers & Balls 18 06-26-2009 12:19 PM
Frame reinforcement - 1973 O'lander Lothlorian Repairing/Replacing Floor &/or Frame 2 02-10-2008 04:46 PM
Reinforcement of Frame Lothlorian Repairing/Replacing Floor &/or Frame 0 12-10-2007 06:15 PM
Reinforcement plate for 76 31ft. sovereign? chris's 67 Repairing/Replacing Floor &/or Frame 2 02-24-2007 09:38 PM
