Old 05-11-2006, 08:22 PM   #1
panabax's Avatar
1984 34' Limited
Dallas , Texas
A/C Ceiling Panel Installation
OK, I recently acquired a 1984 34' Limited. Renovation is in full swing. One of the first things to go was the original A/C. I replaced it with the Carrier low profile 15K btu unit. The new unit looks and works great. However, due to the curvature of the ceiling, the interior ceiling panel does not fit flush with the ceiling. There is a noticable gap in the center of the panel between the panel and the ceiling.
Can anything be done to make it look right on the inside? I searched the forums, but was unable to find a topic addressing this issue.
Panabax
panabax is offline   Reply With Quote
Old 05-12-2006, 04:32 AM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
You could scribe using a circle compass. Set the pencil at the widest gap (most likely the center of the cover) and trace outward. Cut with a coping saw just outside of the line and sand smoothe. I'm assuming the outer edges are touching the ceiling. Refit to AC and touch up areas as needed.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
