Old 07-10-2011, 03:33 PM   #1
1969 27' Overlander
Kimmell , Indiana
Question A/C and wiring question
My 1969 Overlander does not have air cinditioning. I'm considering a roof top unit. I'm wondering if the factory would have run a wire for A/C to one of the roof openings. If so does anybody know which opening? I can only find one 30A breaker in the trailer. Should there be smaller breakers protecting circuits?
Hoosierdaddy is offline   Reply With Quote
Old 07-10-2011, 05:39 PM   #2
bassfiddler's Avatar
1971 23' Safari
Lilburn , Georgia
Andy with Inland RV should be able to tell you if there was a wire installed from the factory for the AC. Some years did but I'm not sure which ones. If there is a wire already installed, and it's connected to a breaker, it will be a 20 amp breaker. The 30 amp breaker is the "Main" breaker for the trailer's electrical panel.
bassfiddler is offline   Reply With Quote
Old 07-10-2011, 05:51 PM   #3
The wiring for a 1969 AC, is already in the ceiling, but it's "NOT" in any vent.
I have a chart at my office that will tell me where that wire is located.
I will post that info tomorrow.
Also, the other end is next to the circuit breaker panel, but "IS NOT" wired into the breaker box.
Old 07-10-2011, 07:55 PM   #4
1969 27' Overlander
Kimmell , Indiana
Thank you, Andy
Old 07-11-2011, 09:26 AM   #5
wiring location
Thank you, Andy
The 120 volt AC wiring is located in the center of the roof, 125 inches rearward of station "ZERO". Station zero is the most forward main bow.
Cut a small hole and fish for the wire. Then you can enlarge the hole, forward or rearward, depending on which AC you get. You will also find a clear plastic drain hose along with the wires. Make sure you purchase an AC that allows you to use a drain pan,or one that has a drain pan built in. If not, water will run down the sides of the trailer, staining the shell..
You will also find the thermostat wiring in the same place.
If your not going to use an AC that has a remote thermostat, then just disregard the thermostat wires.
In case you want to use a thermostat, the other end of those wires are located in 2 different places.
If you have a "double" bed, the thermostat wires are on the road side of the trailer, 66 inches above the floor and 125 inches rearward of station zero.
If you have a "twin" bed model, then the thermostat wires are located 66 inches above the floor, but only 106 inches rearward of station zero.
The beginning of the 120 VAC wire, is in the wall next to the breaker box. You may have to remove the breaker box, in ortder to fish for that wire.
Hope this helps you.
Old 07-17-2011, 06:54 PM   #6
1961 24' Tradewind
Minneapolis , Minnesota
AC wire
I have the same question for my 1961 Tradewind. Is there a wire already in the ceiling? If not, how difficult is it to add one?
61 Streamy is offline   Reply With Quote
Old 07-17-2011, 07:26 PM   #7
1969 27' Overlander
Kimmell , Indiana
Well I've cut a hole 3"X13" in the ceiling 125" aft of the first bow per Andys recommendation. I've found a bundle of low voltage wires and (2) 12-2 w/g romex wires. The romex seems to be just passin through (all wires are aligned fore-aft) and according to my pocket voltage tester both are hot. I cannot find a drain tube either. So far my conclusion is that this trailer was not prepped for A/C.
Actually I ended up drilling out the rivets in that area and peeling the inner aluminum ceiling panels down so I could see and stick my arm up in there to feel for it. Still nuthin....
Old 07-17-2011, 10:31 PM   #8
Those two 12-2 wires "are" for the AC.
Old 07-18-2011, 06:44 AM   #9
1969 27' Overlander
Kimmell , Indiana
Hmmm, I thought the A/C wire would be terminated in that area. These seem to be continuing to the rear .....I'll keep diggin' Thanks Andy!
Old 07-18-2011, 10:02 AM   #10
One goes to the rear where the breaker panel is at.
That dimension is approximate, therefore the ends of the wires might be a little forward of where the hole is located.
Old 07-18-2011, 10:27 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Airstreams didn't have factory wiring in place for a/c until the mid 1960's. Our '63 had the air conditioner wired into the 120 v light wiring. I wasn't enthused about that, but it didn't cause any trouble. Your alternative would be pulling off interior skin to get the needed wires where they go.
Old 07-18-2011, 12:01 PM   #12
HowieE's Avatar
Princeton , New Jersey
Images: 12
There should not be a reason for "TWO" 12/2 wires to feed the AC. And how did you test for voltage without breaking into the shield of the wires.
I suspect you have uncovered general 120 volt receptacle wiring so far.
2004 Excursion 4x4
Old 07-18-2011, 01:50 PM   #13
1969 27' Overlander
Kimmell , Indiana
My thought was that those wires go to receptacles etc. I used a non-contact voltage tester like this Volt Sensor Pocket Tester
There is a breaker box in the front beside and behind the weather/clock in the overhead cabinet. It contains 3 breakers.. all of them connected. I have not found any other wire that is not being used. If I dont find anything else I will try to determine what those 2 wires feed and use one of them if possible
Old 07-24-2011, 04:11 PM   #14
1969 27' Overlander
Kimmell , Indiana
UPDATE... My son has one of those fancy wire tracers that he uses in his business. He put a signal on each of the wires from the breaker box and traced them. He lost signal on one of them about 60" aft of the 1st bow in the ceiling. I proceeded to tear the whole ceiling out and voila!!! the A/C wire. It had been cut and taped off by a P/O. Turns out that originally this unit had A/C but it had been removed.
Now I'm wondering how much of the drain tube they tore out......Havent found a bit of it inside. There appears to be a 1/2" copper tube exiting the floor just inside of the front driver side wheel. I'm going to try pushing a piece of copper wire up that tube and hope it comes out in the ceiling area inside.
Rear A/C wiring in! texascanuk Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-29-2011 04:29 AM
67 Ambassador Wiring Diagram brownv1 Batteries, Univolts, Converters & Inverters 4 06-30-2011 10:06 AM
Water pump wiring question pageclot Water Heaters, Filters & Pumps 6 04-26-2011 07:11 PM
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
nagging wiring question DanielB 1973-1974 Excella 500 4 03-19-2011 06:00 AM
