Old 06-13-2016, 12:42 PM   #1
FCStreamer's Avatar
2014 30' Flying Cloud
A/C Adventures, Part Deux
So my AC is now cooling after the thermostat reset procedure I got from the service guys at Colonial Airstream. Yay!
It is cooling so well, in fact, that in the hot, humid Florida days, the condensation is so much that it is leaking into the cabin.
Sigh.
I had a Dometic authorized tech come out and he said that the AC units were too "low" in the roof and there were some plastic tabs that were blocking the drain holes. He proposed removing the tabs, which requires the removal of the AC units. $250.
Double sigh.
I've read a TON of threads on internal leaking from condensation. My units are draining through a small pipe over the wheel well, but apparently not enough. Running the ACs on high fan alleviates the problem, but proper drainage seems to me to be the correct fix. So I am going to accept the tech's proposal.
Thoughts?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 07-26-2016, 02:49 PM   #2
2007 31' Classic
Buhl , Idaho
A/C adventures, Part Deux
Could you give me a phone number or email address of the person that gave you all the information for the reset. Thanks.
Ray Hoem
goodshepherd is offline   Reply With Quote
Old 07-26-2016, 02:56 PM   #3
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Before you do that take a small diameter wire and clean the drain hose up from the wheel well.
jkcru is offline   Reply With Quote
Old 07-26-2016, 07:00 PM   #4
FCStreamer's Avatar
It was the service guy at Colonial Airstream. And the procedure is outlined in the AC manual.
Old 07-27-2016, 09:19 AM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Please give us the details when the tech does his thing. I guess I have a hard time visualizing what he means by "mounted too low," and the plastic tabs he is referring to are equally puzzling. It sounds like the condensate is making it out of the AC unit and into the condensate drip pan--hard to understand why there would be tabs keeping the drip pan from draining into the condensate tube, when that is exactly what it is designed for.
These are factory installed units, right?
good luck!
Old 07-27-2016, 10:01 AM   #6
FCStreamer's Avatar
Yes, factory installed. We think the problem was too much condensate for the drain tubes to drain properly. He drilled holes in the drain pan to drain onto the roof. That fixed that problem. I still have some minor leakage when I turn the fans off after running all night. Apparently the fan is creating a vacuum and holding onto some water that drains when the fans turn off. Thankfully it's just a few drops.
Old 07-27-2016, 12:51 PM   #7
1990 32' Excella
jonesboro , Arkansas
The plastic tabs could be the tabs that are on some gaskets .they are there so you only tighten the unit down till they touch the top of the trailer.
joel is offline   Reply With Quote
Name Change Part Deux Buttercup WBCCI Forum 32 01-16-2007 06:08 PM
Hello Guest!! Part Deux CanoeStream Our Community 4 12-10-2006 10:03 AM
Adventures of Brett and Edie Part II thenewkid64 Airstream Motorhome Forums 28 12-01-2003 01:36 PM
Adventures of Brett and Edie Part I ViewRVs Argosy Motorhomes 69 07-08-2003 07:06 PM
