Old 04-14-2010, 09:44 PM   #1
1988 29' Excella
Eunice , New Mexico
88 airstream
Just brought home , stopped a few days at koa everything works, but I could not get the furnace to kick on, thermostat klicked box under sink area, but did not start , any help on this , thanks
redex is offline   Reply With Quote
Old 04-14-2010, 09:53 PM   #2
ricknach's Avatar
1978 25' Tradewind
San Bernardino , California
88 Airstream
From the sound of it you have 12 volts going to the furnace that is why you hear the kliking sound. The 12 volts come from the furnace to the thermostat and returns to the funace to run the blower motor. Since the blower motor is not running it could be a frozen motor for the blower. You will need to remove the furnace core and check the blower motor and the wiring from the input connector to the blower motor through the sail switch and overheat switch to the control board.
Rick N
ricknach is offline   Reply With Quote
Old 04-14-2010, 10:04 PM   #3
1988 29' Excella
Eunice , New Mexico
Thank you, I have and appointment at the rv dealer, I can't find the blower motor, just took off the cover , look at , decided to let a rv dealer to fix thanks for the reply.
Old 04-14-2010, 10:23 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
look here too
I found that with a very low battery my furnace did the same thing. Hows your battery?
Old 04-15-2010, 06:28 AM   #5
1988 29' Excella
Eunice , New Mexico
Batts r good, and was plugged in @ KOA , is there a vent off the furnace like a house ? thanks
Old 04-15-2010, 07:16 AM   #6
2010 27' FB Classic
N/A , Texas
Usually chrome, one hole is intake and one hole is exhaust. Look right out side of where the furnace is located, on the side wall of the trailer.
Old 04-15-2010, 08:54 AM   #7
1977 Argosy 24
Milltown , Wisconsin
Also is the LP to the furnace turned on?
ventport is offline   Reply With Quote
Old 04-15-2010, 08:18 PM   #8
1988 29' Excella
Eunice , New Mexico
Thanks , I found the vent on the outside, saw some dirt dobbers , now, I pulled the front of the furnace, found 1 white wire, on the floor, other black wire out of gas detector with only wire in it , my question now is , I pull the furnace out , from what I have read the blower motor or motors ? 2 squirrel cages on back of furnace, Please let me know if I'm right, I will pull furnace in the am , thanks for any advice, great place to have.
Old 04-26-2010, 04:18 PM   #9
gklabs's Avatar
1989 35' Land Yacht
Sherburne , New York
I dont know if you got it fixed yet, but I have a 1989 36ft land yatch 5th wheel and my furnace did the same thing. I would come on and try to ignite but just wouldnt. So I took the burner out and the the burner pan, was all rusty. Its the part with all the holes in it, kinda has a triangle shape to it. I replaced it, $34.00 and now it works like a champ.
gklabs is offline   Reply With Quote
Old 06-07-2010, 03:57 PM   #10
1988 29' Excella
Eunice , New Mexico
Thanks, I found dirt dobbers in the furnace, vents or the rv place did, furnace works great, they told me they got 3 hand fulls out of vents, needless to say I now have vents covered.
