12-27-2006, 02:18 PM
1973 23' Safari
Maryville
, Tennessee
73 Safari Furnace Replacement
Any recommendations on brand/models for replacing the existing Suburban Furnace in my 73 Safari 23? Thanks in advance!
12-27-2006, 03:49 PM
Corona
Suburban NT 30 SP works great.
12-28-2006, 01:28 PM
1974 25' Tradewind
Portland
, Oregon
NT-30sp
Hi Andy,
I am also looking to replace my furnace. Will the NT-30SP also work for a '74 Tradewind 25' Will I need to alter any ductwork? Appreciate the guidance.
Nola
12-28-2006, 02:14 PM
Corona
Originally Posted by nola
Hi Andy,
Nola
You can use the same furnace.
The furnace case must be modified as per a factory bulletin.
A part of the old case is used to make an adapter. Works great.
12-29-2006, 12:13 PM
1974 25' Tradewind
Portland
, Oregon
Hi Andy,
Thanks so much for the info, appreciate it. Do you know where can I get info on the case modification needed? Is this available on thier website?
Thanks again,
Nola
12-29-2006, 12:20 PM
Corona
Hi Andy,
Thanks again,
Nola
Call Airstream Customer/Tech servcie Tuesday at 877-5966505.
They can fax, e-mail, or mail you the instructions needed.
08-21-2011, 01:38 PM
Talent
, Oregon
Andy;
I could use some tips on how to "shear" off the old cab from the plenum so as to reuse. And don't I still need to raise all of that up with the new NT30SP to accomodate the exting exhaust and intake ports.
Thanks, in advance;
Riichard
73 Overlander
