Old 05-24-2011, 08:33 AM   #1
1972 27' Overlander
Owasso , Oklahoma
'72 Overlander AC fan hums when off
My AC on my 72 overlander works great, but the outside fan just barely hums when it is turned off unless you turn off the breaker.
Any ideas what the problem is?
JollyGreen is offline   Reply With Quote
Old 05-24-2011, 09:50 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Relay??
Sounds like the relay that switches it from start to run is not disconnecting the run winding when it should.
Old 05-24-2011, 09:52 AM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Or perhaps it doesn't know the words.....LOL! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 05-24-2011, 10:17 AM   #4
I think you will find that a 24 volt AC transformer is humming, and not the fan.
Old 05-24-2011, 12:01 PM   #5
1972 25' Tradewind
Albany , Georgia
Images: 8
I had a similar issue with my 72 trade wind. It turned out that one of the windings on the motor was bad. My symptoms were that the blower motor was actually running with the ac off. I thought I had discovered perpetual motion. I even took a video of the motor running with the neutral wire disconnected.
Will
meadowlm is offline   Reply With Quote
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 10:26 AM
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 10:21 AM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 12:58 PM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 05:45 PM
Bathroom Fan shepherd57 Argosy Motorhomes 18 03-31-2011 04:25 PM
