Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-04-2002, 10:17 AM   #1
loechli
Profile:  1972 27' Overlander
Saline , Michigan
72 Airstream International Furnace parts
I have a 27' 1972 International with a Surban NT-32A furnace.
I believe I have a bad valve Bastrol Valve # G92SG-D-1 and have been told by Suburban that the furnace was obsolete in 1996.
They can no longer get parts.
I have tried cleaning the furnace but still having problems with valve.
The pilot will light, furnace will turn on.
If I light the pilot but the thermostat is set below current temp,
after about 60 sec I will get a small poof and pilot will blow out.
If I leave the cover off pilot access door I will see a small flame shoot about an inch out the door.
I have been told the gas valve is letting a little gas out.
Does anyone have a source of the Bastrol Valve or a replacement that will work on this furnace?
I have a CO dector and that is fine.
loechli is offline   Reply With Quote
Old 10-04-2002, 01:23 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Mine does the same thing. If I leave the screw on cover off, light the pilot then turn the t-stat up, let the main burner come on for a few seconds, shut of via t-stat, put screw on cover back on,it seems to work OK after that.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-04-2002, 01:38 PM   #3
Ira Iburg
Profile:
I have been getting parts for the one in my 1978 from Camping World
Ira Iburg is offline   Reply With Quote
Old 10-09-2002, 10:00 AM   #4
loechli
Saline , Michigan
Does anyone know of a salvage yard or souce for the Valve for my old Suburban furnace.
Model NT32A
Valve BASOTROL G92SGD-1
Old 10-09-2002, 10:35 AM   #5
74Argosy24MH
Profile:  LOST , Hawaii
Try this, a bunch of salvage and surplus outfits
RV Net
John
74Argosy24MH is offline   Reply With Quote
Old 10-09-2002, 10:50 AM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The usual reason that furnace was replaced, is because of the same failure.
Your not likely to find a used valve that will be OK.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-20-2008, 05:45 PM   #7
Robert Alleg
Flower Mound , Texas
I need a jack handle for a 72 airstream. We are talking about the leveling jacks under the body of the unit. Just bought mine and I am pumped,always wanted one or two.
Robert
Robert Alleg is offline   Reply With Quote
Old 08-20-2008, 07:17 PM   #8
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Are you talking leveling jacks or the stabilizers that are physically attached to the undercarriage of your trailer? If the latter, all you need is a socket wrench. You can also attach the socket to a drill for faster results.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
34.5 Furnace parts charlief1317 Airstream Motorhome Forums 1 01-20-2004 04:59 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
