When I first fired this furnace up it smelled awful-I assumed it was because of a bad crossover rubber tube--so out it came-and in the process of cleaning I pulled out the homes of many mud-daubers [from the exhaust pipe]-This had to be the cause of the smell-the exhaust couldnt get out! Also, after looking at it for 20 mins. I found the elusive rubber crossover tube-all cracked up,and in a very tight spot down low in the very back of the furnace--To remove it I just unscrewed the blower, tilted it alittle and exposed the crossover area[its the pic showing two round holes,which have been separated to get the tube out] I then cut a piece of steel pipe[2 7/8'od] to exactly the same length as the rubber one[1 1/2"] All this thing does is bring in fresh air to the furnace combustion box--I really dont see the harm in just leaving the old cracked one in place--thanx everyone for your help! hope the steel one works ok
--jim from mich
