Old 06-09-2015, 07:04 PM   #1
1969 29' Ambassador
Hartselle , Alabama
69 Ambassador
I need to replace my Armstrong ac unit. How do I remove the inside shroud and upper unit. Any help would be greatly appreciated.
dave69 is offline   Reply With Quote
Old 06-09-2015, 09:52 PM   #2
1968 28' Ambassador
Dover , Arkansas
Start drilling out rivets on the inside shroud after removing fan blades. On outside start unscrewing the unit frame or housing from the top of the AS. There's a couple of rivets inside the frame/ housing.You will have to cut the Freon lines after recovering the R22 coolant. Cut them where you can pull straight down into the inside of your AS. To remove inner cooling coils. Make sure power Is cut/ breaker is open and cut the power supply lines keeping as much slack as you can. Good luck. Jim
Eagleuh1 is offline   Reply With Quote
Old 06-09-2015, 09:55 PM   #3
1968 28' Ambassador
Dover , Arkansas
And recycle the unit, offer it for parts before scrapping it if you can. Some of us like trying to fix these things. Thanks. Jim
Old 06-09-2015, 10:43 PM   #4
1971 31' Sovereign
Indian Wells , California
I'm still looking for the interior plastic cover if you have one.
CraigCA is offline   Reply With Quote
Old 06-10-2015, 06:31 AM   #5
1969 29' Ambassador
Hartselle , Alabama
The round filter?
Old 06-10-2015, 07:09 AM   #6
1971 31' Sovereign
Oh maybe 69 had a different Armstrong AC than my 71?
The interior plastic cover was missing on mine when I got it so I'm now even sure what it looks like.
Old 06-10-2015, 07:21 AM   #7
1969 29' Ambassador
Hartselle , Alabama
Mine is all metal.
Old 06-10-2015, 07:27 AM   #8
1971 31' Sovereign
They must have changed them. Thanks
Old 06-10-2015, 08:20 AM   #9
1969 29' Ambassador
Hartselle , Alabama
I think the '69 was a changeover year. There are differences from the '68 & '70.
Ambassador Kinton :: 1965 Airstream Ambassador International sckinton Airstream Registry Discussions 0 08-17-2013 01:17 PM
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 10:07 PM
electrical diagram for a 1966 Ambassador 28 foot ups guy Electrical - Systems, Generators, Batteries & Solar 2 09-10-2004 04:24 PM
What is an Ambassador Model dinoburb Airstream Trailer Forums 1 01-01-2003 07:56 PM
