Old 07-27-2010, 01:29 PM   #1
Benvenito
1965 26' Overlander
Chatfield , Minnesota
Images: 8
'65 Overlander no power to A/C or outlets
Well, I've discovered both the A/C and all the 110 plug in outlets on my '65 Airstream Overlander are without power. Breakers look good. Fuses look good. Pulled out switch on A/C and there's no power to it. HELP!!! It's over 90 in there and I'm redoing subflooring and tiling! thanks!
Ben Volker
Chatfield, MN
"Ask not what your Airstream can do for you,
but what you can do for your Airstream."
[apologies to JFK]
"It's not the destination, but the journey."
Benvenito is offline   Reply With Quote
Old 07-27-2010, 08:33 PM   #2
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
You can do what I did to trace down your problem. Do you have power to the breakers? Input and output? If not then trace back farther, the line to your electric supply plug does it have power? Check the breaker at the house. I found that all of mine were hot. So it had to be the thermostat. But yours must before it even gets to the AC. Keep checking until you find where the power is hot and the problem should the next thing in line that isn't. Just because the fuses look good does mean that there is power to them. If you don't have a circuit tester get one. Even one of those cheap little ones that cost a few dollars would be fine. I have a professional one but that is because I use it in my work. I alway carry one of those little ones in my tool box just in case.
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Automatic power jack on my 1970 Overlander Airstream will not work.... richeille Jacks, Stabilizers, Lifting and Leveling 11 07-28-2010 06:00 PM
What outlets are available when using battery power? jagzoo Batteries, Univolts, Converters & Inverters 26 06-01-2010 02:08 PM
Where have all the outlets gone - 2003 Classic. wxbuoy 2001 - 2005 Classic 8 12-07-2009 02:45 PM
GFC 110 outlets adonh Electrical - Systems, Generators, Batteries & Solar 2 04-28-2009 07:22 PM
