Old 05-07-2005, 10:37 AM   #1
2011 23' FB Flying Cloud
Augusta , Kansas
64 Bambi II
Is a 64 Bambi prewired for AC and if not is this a difficult task? Thanks
submirj is offline   Reply With Quote
Old 05-07-2005, 11:57 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
64 Bambi II
Greetings submirj!
The balance of the Airstream line was pre-wired for air conditioning in 1964, but the Bambi II may have been an exception to the general rule. One clue as to whether the coach was pre-wired is the existence of an unused circuit breaker or circuit breaker bay. The other issue to be considered is that you will need the factory specification for location of the air conditioner -- the factory bracing and wiring were not generally run to an existing roof vent, rather the location was determined by a measurement from the front main roof bow to the rear where the hole for the air conditioner mounting would be cut. One possibility would be to contact customer support at the factory using the information below:
Airstream Corporate Contact Information
I know that I have seen several '64 Bambi II coaches fitted with air conditioning so know that it has been done, but the precise location for the installation opening and whether it would have pre-wire available are both question marks.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
