Old 11-09-2003, 02:01 PM   #1
1971 excella500 armstrong AC
I recently purchased a 1971 Airstream Excella 500. The Armstrong A/C unit works. I do need to replace the compressor. I am hoping to find a Compressor for the unit that is original or contact the company to see what would be a satisfactory replacement for the compressor.
I would like to keep the system a original as possible. Everyone I have talked to says to keep the Armstrong unit if at all posible.
Chris Deeley is offline   Reply With Quote
Old 11-09-2003, 02:59 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chris
here is a link that may help.
http://www.tpc-nacg.com/techdocs.htm
a member here did a one for one replacement using a compressor from tpc. with success.
i can't for the life of me remember who it was!
hopefully they will chime in!
john
you call them ferrets, i call them weasels.
Old 11-09-2003, 03:15 PM   #3
Chas's Avatar
Images: 22
Chris,
Maybe I am missing something. If it works then why do you need to replace the compressor?
Maybe you should check the control wiring, contactors and the capacitors first.
Chas
Chas is offline   Reply With Quote
Armstrong AC experience - so far silvercomet Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-03-2003 08:11 AM
Armstrong AC unit pics FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-05-2002 03:26 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
