Old 10-06-2010, 08:45 PM   #1
Lothlorian's Avatar
Loganville , Georgia
196O Overlander buying an Attwood furnace?
My heading is there because I need some advice. I have a possible deal. I can get a 25,000 or a 30,000 Btu Atwood Furnace with a warranty for incredible price. The price is a no brainer. I want to use it in my 1960 Overlander. I would put it where the old furnace is and use the old furnace doors and chimney.
Can I make it work. What do you think of Atwood 37637, Furnace 25000Btu ?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 10-06-2010, 09:04 PM   #2
nmbosa's Avatar
Nowhere , Washington
Look into how it may be installed. Check whether it needs to sit against the outside skin, or can if it be installed against the inside skin with just the vent tube going through the wall? If the entire unit needs to be against the outside skin, you may run into a vertical rib in that area where your current furnace is located and you do not want to cut those. It looks short enough to avoid the horizontal rib, but you'll want to check that also.
I noticed it can be installed vertically if necessary, so that may be a way to avoid the vertical rib, but you would probably need to cut a horizontal rib in that case.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 10-07-2010, 12:51 PM   #3
Lothlorian's Avatar
I am bringing this to the portal again. Do I have to put the cover plate on the Attwood furnace? I do not want to cut out a huge hole in my trailer. I want to bring the exhaust pipe out of the metal and put the small chrome cover plate on it. the attwood lays horizontal and it has a huge cover plate that is supposed to sit outside the trailer. I was wondering if anybody has ever put one of these in.
If I can't I will just pay the price for a Suburban. I bringing this subject up again because I have a great deal in front of me. I don't want to buy a brand furnace that one work. My other trailers suburban works great.
Brian
Brian & Adrienne
Thinking about buying a '64 Overlander - Questions mello mike 1960 - 1964 Overlander 8 04-26-2010 07:23 AM
Looking at buying '74 23' Overlander. Is it overpriced? mile2885 Trailer Values 13 12-28-2009 02:36 PM
Thinking of Buying 1974 Overlander Sylia WBCCI Forum 8 04-02-2009 08:48 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
buying a 1973 Overlander enomrah Commercial Listings 3 03-24-2005 01:16 PM
