Old 12-24-2015, 09:57 AM   #43
1951 21' Flying Cloud
1954 22' Flying Cloud
columbus , Ohio
install
If you are looking for a cheap way to avoid the unit on the roof ,that does not distribute the air very well, this is not for you. The unit is about $4000 retail.
finn21 is offline   Reply With Quote
Old 12-24-2015, 10:01 AM   #44
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Ouch!
Split system is less than 20% of that cost, but cannot be hidden to preserve the vintage look. Horses for courses, as they say.
BambiTex is offline   Reply With Quote
Old 12-24-2015, 10:24 AM   #45
columbus , Ohio
In most of the split systems, and the rooftop units the supply and return are the same place and you don't get much circulation.
Old 12-24-2015, 10:31 AM   #46
columbus , Ohio
could always do something like this
Old 12-24-2015, 11:55 AM   #47
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
this guy obviously left home w/out his duct tape
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 12-24-2015, 04:55 PM   #48
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
I am curious if you have a door on your intake so that dust does not work its way up as you travel. On a dusty road it infiltrates your trailer where ever possible.
I guess you will find out based on how often you need to replace the filter.
FC7039 is offline   Reply With Quote
Old 12-24-2015, 07:24 PM   #49
columbus , Ohio
filter
there is a filter on the condenser intake, I'll keep an eye on it
Old 12-25-2015, 09:26 AM   #50
1965 30' Sovereign
1969 23' Safari
Redgranite , Wisconsin
Very nice. Thanks for sharing.
Lots to do. Getting there.
65Streamer is offline   Reply With Quote
Old 12-25-2015, 10:06 AM   #51
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Haymaker
Haymaker II Custom Air Conditioning System - Restomod Air
Grapevine , Texas.
Old 12-26-2015, 02:06 PM   #52
calais66's Avatar
Sacramento , California
So cool and a beautiful rig both inside and out! A bit off subject, but did you replace the original leaf springs with a torsion axle during your original resto? We're at that point with our '51 and want to keep the low stance which yours still has.
calais66 is offline   Reply With Quote
Old 12-26-2015, 03:14 PM   #53
columbus , Ohio
axle
The trailer has the original leaf springs with a newer replacement axle currently, but I am considering replacing it with a torsion axle, from Colin Hyde. I have only about 2 1/2 inches of travel before the axle hits the frame rail. I understand the torsion axle would raise the trailer about two inches and I could add shocks[I don't have any now]
Old 12-26-2015, 06:54 PM   #54
rideair's Avatar
finn21,
You could always increase the length of the shackle plates, many off-road folks do this for increased height at a lower cost while keeping the same ride. For once, something really can be "Quick, Cheap and Easy".
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 12-27-2015, 10:13 AM   #55
calais66's Avatar
Thanks!
Old 08-22-2017, 07:43 AM   #56
columbus , Ohio
update
The 1951 has been down by the lake all summer, in the sun and the self contained system has worked perfectly, maintaining a constant 74 degrees inside with outside temps in the mid 90's. I have it plugged into a woodshed with two 100 ft 14ga extension cords.The only problem has been that in the spring I had a wild turkey, seeing his reflection, bang his wings and head against the trailer, to the point that there was feathers and blood on the side. There was no dents, but now I am worried about the upcoming deer rut. Anyone ever have trouble with deer wanting to fight their reflection?
flying cloud :: 1951 Airstream Flying Cloud finn21 Airstream Registry Discussions 1 04-05-2018 06:24 AM
1951 flying cloud self contained a/c finn21 1950-1955 Flying Cloud 2 06-10-2016 04:32 AM
self contained table Happycampers General Interior Topics 2 05-11-2007 06:41 AM
Self Contained??Mobile?? Codger Airstream Trailer Forums 16 01-12-2005 01:55 PM
