12-24-2015, 08:27 AM
#41
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Very NICE! I agree with Brad. I am following this subject for my Liner in progress.
12-24-2015, 08:38 AM
#42
1955 22' Safari
Laredo
Excellent install!
May I ask what it cost?
12-24-2015, 09:57 AM
#43
1951 21' Flying Cloud
1954 22' Flying Cloud
columbus
, Ohio
install
If you are looking for a cheap way to avoid the unit on the roof ,that does not distribute the air very well, this is not for you. The unit is about $4000 retail.
12-24-2015, 10:01 AM
#44
1955 22' Safari
Laredo
Ouch!
Split system is less than 20% of that cost, but cannot be hidden to preserve the vintage look. Horses for courses, as they say.
12-24-2015, 10:24 AM
#45
columbus
, Ohio
In most of the split systems, and the rooftop units the supply and return are the same place and you don't get much circulation.
12-24-2015, 10:31 AM
#46
columbus
, Ohio
could always do something like this
12-24-2015, 11:55 AM
#47
1960 24' Tradewind
Folsom
this guy obviously left home w/out his duct tape
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
12-24-2015, 04:55 PM
#48
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
I am curious if you have a door on your intake so that dust does not work its way up as you travel. On a dusty road it infiltrates your trailer where ever possible.
I guess you will find out based on how often you need to replace the filter.
12-24-2015, 07:24 PM
#49
columbus
, Ohio
filter
there is a filter on the condenser intake, I'll keep an eye on it
12-25-2015, 09:26 AM
#50
1965 30' Sovereign
West Allis
, Wisconsin
Very nice. Thanks for sharing.
12-25-2015, 10:06 AM
#51
1953 32' Liner
1955 22' Safari
Valley View
Haymaker
12-26-2015, 02:06 PM
#52
Sacramento
So cool and a beautiful rig both inside and out! A bit off subject, but did you replace the original leaf springs with a torsion axle during your original resto? We're at that point with our '51 and want to keep the low stance which yours still has.
12-26-2015, 03:14 PM
#53
columbus
, Ohio
axle
The trailer has the original leaf springs with a newer replacement axle currently, but I am considering replacing it with a torsion axle, from Colin Hyde. I have only about 2 1/2 inches of travel before the axle hits the frame rail. I understand the torsion axle would raise the trailer about two inches and I could add shocks[I don't have any now]
12-26-2015, 06:54 PM
#54
finn21,
You could always increase the length of the shackle plates, many off-road folks do this for increased height at a lower cost while keeping the same ride. For once, something really can be "Quick, Cheap and Easy".
Enjoy,
Paul Waddell
12-27-2015, 10:13 AM
#55
Sacramento
Thanks!
08-22-2017, 07:43 AM
#56
columbus
, Ohio
update
The 1951 has been down by the lake all summer, in the sun and the self contained system has worked perfectly, maintaining a constant 74 degrees inside with outside temps in the mid 90's. I have it plugged into a woodshed with two 100 ft 14ga extension cords.The only problem has been that in the spring I had a wild turkey, seeing his reflection, bang his wings and head against the trailer, to the point that there was feathers and blood on the side. There was no dents, but now I am worried about the upcoming deer rut. Anyone ever have trouble with deer wanting to fight their reflection?
08-22-2017, 07:44 PM
#57
1960 33' Custom
Athens
, Georgia
I'm very happy to see one installed at last! I think i might either go with one or two of these on my project. I'll only bail and go with a residential portable unit if I splurge too much in other parts 🙄 If you have any other instal pics or instal info I'd really like to hear more
William
12-31-2017, 10:57 AM
#58
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
finn21
My compliments to you on your excellent seamless installation of your heater/air conditioner. So glad that it is working so well for you.
Dan
01-02-2018, 08:35 PM
#59
1966 22' Safari
Fredericksburg
Dometic ASCEQ14
Mr. Finn21, I have tried searching for the information given on the AC you installed, but came up empty. I called Dometic and they were no help. Do you know if the unit is discontinued? I would appreciate any leads you can give me. Thanks, Bubba
01-04-2018, 09:57 PM
#60
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Bubba
I would contact the installer, Creative Mobile Interiors. Since they have installed a number of these units they should know where to get them or an alternative.
Dan
