Old 05-07-2017, 05:19 PM   #1
2019 30' International
Pennsylvania , Pennsylvania
'16 Flying Cloud 25a heat pump condensate running down outer skin
Wow, I've searched, and read, and pondered.
We have what I believe to be a condensate tube exiting the driver side front wheel well of our 2016 flying cloud. It's a nice size tube, I'll guess an inner diameter of a half inch or more.
When we run our heat pump, water comes down the side of our airstream.
I'd like some clarification.
1.) Is heat pump condensate supposed to run down this tube or not? (I've read maybe not, possibly just A/C condensate)
2.) If heat pump condensate IS supposed to run down this tube, then what we may have is a warranty issue.
3.) Since I'm kinda handy, if there is an easy fix, please advise.
I have read about compressed air up.....compressed air from top down (though I'd like to know a detailed method how/where to access the condensate tube on our unit from the top.....stout trimmer line shoved up the tube, etc. etc.
Any help appreciated, I'd like to repair myself, but will tow to Ohio, or a reputable mid atlantic dealer that could fix, if necessary.
thanks,
majorairhead
majorairhead is offline   Reply With Quote
Old 05-08-2017, 06:24 PM   #2
2015 28' Flying Cloud
Newtown , Pennsylvania
Both of my air conditioners in heat pump mode do the same thing. It is because the condensate is coming off the condenser in heat pump mode. The condenser drains on to the roof.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 05-08-2017, 06:38 PM   #3
Bruce
Thanks for your response Bruce, I truly appreciate it. I'm just totally not familiar with how the dometic ac works but am learning
AC condensate tube on 2015 25' FB Flying Cloud GLovedahl General Repair Forum 9 10-20-2016 04:47 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Outer skin of unit (roof to outer wall) jaharper Ribs, Skins & Rivets 1 08-01-2011 01:05 PM
