Old 07-10-2006, 12:12 PM   #43
Originally Posted by crowbar68
i agree, i think the circuit breaker is doing its job. you probably need to go to a 30amp breaker.
And 10 gauge wire. Don't shortcut and use 12 gauge. That would be dumb.
Barry2952 is offline   Reply With Quote
Old 07-10-2006, 12:35 PM   #44
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
i concur barry, that would be dumb.
crowbar68 is offline   Reply With Quote
Old 07-10-2006, 01:04 PM   #45
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Over the 4th we were in central FL and the temp got up to 98 one day and our breaker at the camp ground pole kept tripping. All of the others around us did too. I figured it was kind of like a brown out. I was glad we were at the camp site because our dog would have been alone without A/C if we hadn't.
I assumed it happened because so many A/C's were working so hard to try and cool the various campers that the voltage available dropped too low. After a few minutes the breaker tripping stopped. I guess after enough breakers tripped cutting off power to the voltage hungery A/C units in our loop there was finally enough power available to run our A/C.
Next time I will switch the fan speed to high in stead of auto and see it that makes a difference. If it's going to be hot, I'll leave the fan speed on high when we leave as a safety precaution. However, I doubt that would have made a difference considering the other loading that was in place.
Family of Disney Fanatics
WBCCI# 4821
Old 07-10-2006, 01:43 PM   #46
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Based on the fact that everyone was having issues, this probably wouldn't have helped you. At 98 degrees you probably should have that fan on high anyway just to get better air distribution and to allow you AC unit to run at its best efficency. You don't get much if any compressor cycling in those temps unless you are in the shade.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-10-2006, 02:32 PM   #47
2006 30' Safari
Orlando , Florida
Originally Posted by GlenCoombe
I'm going to take a temp reading of the skin with a laser thermometer when it's complete just for a comparisson.
One thing I might add about IR/laser thermometers. They work by measuring the amount of infrared light emitted as heat by the object giving the temp measurement. When the visible spectrum of light is reflected, so is the invisible spectrum which includes the infrared band. So when you point your laser thermometer at the roof of your MOHO in the before senario, you are registering the infrared light waves that are being emitted as heat given off by the aluminum as well as the infrared light that is being reflected by the aluminum. When you paint the surface white, you will be reflecting more light, including infrared light, than the semi matt oxidized aluminum you had before. This will probably result in a higher reading with your hand held laser/infrared thermometer giving you a false higher reading. You would be more accurate to shade the spot you are taking the measurement from after it has sat in the direct sun long enough to reach its highest temperature. You can use your hand or a piece of cardboard or anything that is opaque to provide this shade to the actual spot AND the entire path between your thermometer and the spot you will take your measurement from to prevent reflected ambient infrared light from tainting the reading.
WBCCI# 4821
Old 07-10-2006, 02:42 PM   #48
I'm about to purchase an EPDM membrane roof for the "Toybox". I'm looking for some new sources as the prices I'm getting seem rediculous.
I priced 45 mil black rubber at $139. for a 10' x 50' roll. A 9 1/2' x 24' piece of EPDM from Camping World is $450.00. Wouldn't commercial roofing in white do the same thing?
Camping world offers gray, white and tan. Any difference in reflectivity of those colors?
Old 07-11-2006, 09:14 AM   #49
2006 30' Safari
Orlando , Florida
White is the most reflective since it reflects all light wave lengths and would result in the coolest temperature underneath. Tan would be the next coolest since it reflects more of the light band including the reds where most of the heat source colors are contained. Grey would be the least since, like black, it absorbs the most colors. In other words, the tan would reflect the red spectrum including the infrared which includes most of the heat source of light. The grey absorbs most of the light spectrum including the reds where the most of the heat containing red color is.
You could try an RV dealer for a quote or you could check with a commercial roofer who specializes in single ply roofs. It might be too exotic for a commercial roofer, but if not I would think $7-$10 per square foot should be about right depending on your area.
WBCCI# 4821
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
