Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 09-21-2003, 03:17 PM   #1
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
15k BTU A/C unit info
Been working with Airstream through a dealer over the past few weeks and I came across something interesting in regards to the 15k BTU A/C. This size unit is clearly a listed option in the 25' and larger Classic line. In the Classic line, they have a comfort control center which is basically a thermostat that controls both the furnace and the A/C.
From what I have been told, if you go to the 15k BTU A/C unit in any model that will accept this unit (usually 25' or larger, even though it is not a listed option in non-Classic coaches), the comfort control center replaces the standard furnace only controls that the non-Classic rigs get. Apparently, the 15k unit has no controls on it???
At any rate, for those interested in the 15k A/C option, you may see an added bonus here.
Regards,
Eric
A/C unit size input.... Silvertwinkie Our Community 4 09-04-2003 07:05 AM
front Coleman a/c unit zduke4x Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2003 03:48 PM
Electrical & 15000 BTU A/C gklott Electrical - Systems, Generators, Batteries & Solar 1 06-19-2003 07:02 PM
btu of a/c unit Mikie 1969 Overlander 7 05-11-2003 01:43 PM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 09:19 AM
