12-28-2016, 11:12 PM
2008 19' Bambi
Carlsbad
13.5 k or 15 k BTU for 19' trailer?
We are new owners of a Bambi 19' that had a damaged Dometic Penguin AC. I am seeking a suitable replacement and wonder if a 15000 btu unit would be desirable over the stock 13500 unit, or would it be too much cool? The cost difference is only about $100.00. We have 2 Honda 2000i gennies. I have read hundreds of posts regarding this debate, but all of them were regarding 25' to 40' trailers. Does anyone on the forum own a 19'?
Russ
12-29-2016, 12:17 AM
Mantua
, Ohio
You could go with a single 11000 unit and run it off one generator.
12-29-2016, 04:49 AM
2015 16' Sport
Lakeridge
, Virginia
Wish it would, but my Honda 2000 won't run Peanut's 11000 unit.
12-29-2016, 05:16 AM
Mantua
, Ohio
Okay then try a 9000 unit, it's a tiny trailer. The 11000 should run off a 2000, I think.
12-29-2016, 05:42 AM
1955 22' Safari
Laredo
Smaller is better
I cool my 22 ft Flying Cloud with a 12,000 BTU and it provides plenty of cooling even in the Texas heat and humidity. Of course it is a split system inverter style A/C which runs easily on single (propane) Honda 2000.
12-29-2016, 06:14 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Air Conditioner - Dehumidification
Originally Posted by Ruscal
... I am seeking a suitable replacement and wonder if a 15000 btu unit would be desirable over the stock 13500 unit, or would it be too much cool? ...
As well as cooling you want your air conditioner sized properly so that it will dehumidify the air too. Modern air conditioners dehumidify as they cool; you can see that by the water that drains away, but this dehumidification is incidental to their main job of controlling temperature. They cannot independently control both temperature and humidity. If an ac unit is too large for the space it will cycle on and off too often as it can easily cool the air, but to remove humidity the ac should have to 'work hard', i.e. run longer and/or more often. Sometimes smaller is better.
Do not set your thermostat to the “fan on” position. In this position the fan blows air all the time whether your cooling system is running or not and one key impact is that a lot of the moisture your system just took out of the air, will be blown back into the coach before it can drain way.
Ray B.
12-29-2016, 07:55 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Russ
There is no need for a larger unit in your trailer.
If it were me, I would install an exact same replacement. That way all of the wiring and the condensate drain will fit perfectly without modification. It should cost less for install labor if it's plug and play. A pro can change it out in around an hour.
Alan
12-29-2016, 12:12 PM
2017 30' Flying Cloud
Spotsylvania
, Virginia
The smaller unit requires an 15 amp circuit, the larger unit requires a 20 amp circuit. Which means the wiring would need to be replaced as well as the circuit breaker.
Stick with what the AS guru's specified unless you have more money than brains.
12-29-2016, 02:20 PM
2008 19' Bambi
Carlsbad
I think those split units are more efficient than the low profile Dometic Penguin ll units. I also have a 16' Scamp with a 9000 BTU Mini Mach that I have not tried to run with one 2000i. It might start it but we always ran 2 gens.
Russ
12-29-2016, 02:34 PM
2008 19' Bambi
Carlsbad
Thanks Alan,
You may be right about not needing more cooling. Most posters with 25 footers were wanting more cooling than 13.5, but their cabins are 6' longer than mine and the air wouldn't travel to the far end. Some of those people chose the 15k option over adding another unit.
The install is identical for both units. Same drain kit, and layout. The factory provided 12 gauge wiring and a 20 amp breaker in my trailer. The actual current draw would be higher with the 15k unit, but the 2 gennies would run either.
Russ
12-29-2016, 02:45 PM
2008 19' Bambi
Carlsbad
Ray,
I remember hearing this before about AC systems function better when having to work harder.
I read something about the newer Dometic thermostats can cycle the fan with the compressor or have both shut off together when cycling. When set to "auto" it leaves the fan running (I think). I do have to change the old 5 button thermostat to a digital ccc2 to work with the Penguin 2, so will have to learn what all those buttons do.
Russ
12-29-2016, 03:29 PM
Mantua
, Ohio
Is that true?
12-29-2016, 03:54 PM
2000 25' Safari
Davidson County
Is that true?
No.
This is link to a brochure that states that a 20 amp circuit is specified for all Dometic Penguin units.
http://dometic3frontend.qbank.se/epi...031957a824.pdf
Alan
12-29-2016, 04:42 PM
Mantua
, Ohio
Thank you.
12-29-2016, 06:56 PM
1973 Argosy 24
hartselle
, Alabama
A single 13500 keeps my 24` very comfortable.
12-29-2016, 07:06 PM
2002 30' Classic S/O
Fleming Island
Our 2001 Safari 25 had a 11,000 BTU unit which was completely adequate and would run from our single EU2000i Honda. Planned to test the voltage sag and current drain when starting to ensure that the compressor was not being stressed but never did it before I traded trailers. The 25 had the "mousefur" walls and vinyl ceiling. I think that contributed to the insulation factor over the newer exposed aluminum walls.
I'd put in whatever was originally there and expect it would be fine for cooling in most, if not all locations. As was mentioned previously, you don't want to go much oversized or you will not be removing humidity adequately.
Al
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
13500 BTU vs. 15000 BTU
Eddie25 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
14 |
12-20-2013 11:50 PM |
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help?
bowhead13 |
47 |
07-19-2013 12:02 PM |
15K BTU Brisk Air vs. 15K BTU Penguin
adwriter73 |
9 |
05-23-2011 10:32 AM |
New Furnace BTU size for 31ft trailer
Kstar |
7 |
02-06-2006 02:47 PM |
BTU's
Andy Wick |
2 |
11-27-2002 09:04 PM |
