Old 07-07-2011, 07:03 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
will a good quality residential range survive in an Airstream?
Tried one of the Fisher & Paykel dual fuel Propane / 120v and really liked it.
Has a Wok burner
and the electric oven is 2200W 240v which I can handle with my inverter or shore power.
This is how the electrical load breaks down..
- Lower heating element (double) 500 + 1300 W
- Upper heating element 1000 W
- Grill heating element 2000 W
- Circular heating element 2200 W
If I decide to go this route will it survive in an Airstream?
Are RV ranges that much different than a residential range?
Thanks..
24" Dual Fuel OR24SDPWGX1 by Fisher & Paykel United States of America
Darkspeed is offline   Reply With Quote
Old 07-07-2011, 07:13 PM   #2
OO , OO
Send a message via Skype™ to cruiser54
The products of company Fisher & Paykel look everybody fantastic!
cruiser54 is offline   Reply With Quote
Old 07-07-2011, 07:39 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
3 things - weight could be an issue - size could be an issue - durability could be an issue.
They look well built and beefy. I have to think they would weigh more than a typical RV appliance.
Most RV oven/cooktops don't have the bottom drawer so this may affect where it's placed in the trailer. Limits setting it over the wheel wells.
Are these built to handle the constant movement/vibration that an RV appliance is subject to when traveling?
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 07-07-2011, 07:45 PM   #4
Darkspeed's Avatar
1972 31' Sovereign
Im starting with a blank floorplan so placement is not really a problem..
It is 24" wide and counter depth..
Seem VERY well made..
I could break it down and hit everything with locktite red..
Had this in the book but It may be in all the books as boilerplate:
3. Installation in Recreational Park Trailers: installation must
conform with state or other codes or, in the absence of
such codes, with the Standard for Recreational Park
Trailers, ANSI A119.5.
Old 07-07-2011, 08:23 PM   #5
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I'm not 100% sure but I think park trailers stay stationary once they're setup. I'd contact the manufacturer about using them in an RV that travels.
Dennis
Air #4056
Old 07-07-2011, 08:30 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
1. RV "Park" trailers are more like small mobile homes and once set up the axles are removed.
2. I doubt you will have enough battery power to bake a cake on inverter and think you should plan to use it on gas anytime you did not have 50amp service.
3. I would install propane only but that is me, I suspect it would hold up OK.
4. A gas range "must have" a vent to the outside so where ever you put it you will have to install a vent.
Garry
Old 07-07-2011, 09:29 PM   #7
Darkspeed's Avatar
1972 31' Sovereign
Most likely under the existing roof vent on my 31'
Well lets see 24v 428ah @ 4hr rate (570 @ 24hr -or- 4X 12v @ 258ah -or- 660lb of AGM eek)
2200w / 24v = 92a
428 / 92 = 4.65 hours till zip.. < you would not want to do that
30min avg to bake a cake
4.65 * 0.5 = 9.3 cakes if I drove my bank into the ground not counting the 10% loss in the inversion process and the design factor at a given temp.
I have not had my coffee so i dont stand by the math 100%
Old 07-08-2011, 09:49 AM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Where do you find 240v at an RV park? I guess you don't plan to travel with it?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 07-08-2011, 10:19 AM   #9
Darkspeed's Avatar
1972 31' Sovereign
Pat
I can convert 30 amp 120 shore power to 240 through my on board inverter
Or
The 50 amp 240 receptical as I'm building mine for 50a 240v like the big campers
Old 07-08-2011, 10:28 AM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
RV ranges are smaller.
RV range: 22w x 22h x 20d
F&P range: 24w x 36h x 24d
Since a household range will extend all the way to the floor you lose a few inches in depth due to the slight rounding of the trailer walls so you'd end up losing 6-8" in corridor space. I would think that's the main drawback.
You would also want a matching wider range hood.
Old 07-08-2011, 10:34 AM   #11
Darkspeed's Avatar
1972 31' Sovereign
Jammer, that's a good point! Had not thought of the curve
Old 07-08-2011, 11:18 AM   #12
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
CAUTION:
Fisher & Pascal is a great appliances and i have installed those in Yachts and some larger RV's. Here your biggest Concern: if you buy the European version for 240Volt, they WILL NOT work on 240V US because US is 60HZ Cycle and European is 50HZ. Your converter will boost the voltage but not change frequencies. I know, some people will now say, its a stove, don't worry about frequency, BUT the internal electronics, starters, clock and so on will NOT work. (been there done that ). So My Advice : try to get a US Version or a different manufacturer, that has a nice Oven/ Stove.
Also , if you update to a large oven / stove, i would strongly recommend to either change the camper to 50 Amp service or add a second 30 amp Supply. your single 30 amp supply will not handle the stove and the AC. Unless you have only one at the time on.
Also run a new wire to the breaker panel in the correct size. The factory "receptacle " wire is too small and will burn.
My 2 cents
Stefan
Electrical Engineer
submariner is offline   Reply With Quote
Old 07-08-2011, 11:30 AM   #13
Darkspeed's Avatar
1972 31' Sovereign
Thanks Stefan
The one I am looking at is 240v 60hz and I am wiring 50a service
Old 07-08-2011, 12:08 PM   #14
submariner's Avatar
1948 22' Liner
1989 34' Limited
thats good. here some more info : If you run all burners at the same time, you are at 7000W , which comes out to 30 Amp.
Use at least a 10 gauge cable. It is rated for 35 Amp Max.
I need Help Buying 2005 Airstream Westfalia in Piedmont SC PorcupineRim Our Community 3 03-19-2011 05:16 PM
Workamping Opportunity At Penn Wood Airstream Park DEITZ645 Working on the Road 0 03-14-2011 11:58 AM
Airstream Trailer, Vintage Airstream, Airstream eBay Watch Airstreams on eBay 0 02-10-2011 08:10 PM
