Old 01-25-2016, 08:33 AM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Why do all replacement ranges look so cheap?
We're at the end of the renovation of our '79 Excella and at the point where I need to find a replacement for our MagicChef cook-top/oven. We actually didn't mind the way the oven looked, and it felt quite sturdy, but it seems like all the modern replacements out there look and feel so cheap! I chalk it up to cost cutting measures over the years, but essentially we're stuck with either an Atwood or Suburban cook-top/oven if we go with a model that's made for an RV.
In search of a visually appealing replacement, we've broadened our search to include cook-top/ovens for boats.
Has anyone gone this route (using a marine cook-top/oven in your airstream)? If so anything I should consider that you normally wouldn't?
Lastly, can anyone recommend a source to find good selection of marine appliances? To date I haven't found many...
trekerboy is offline   Reply With Quote
Old 01-25-2016, 08:43 AM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Agree 100%. I think it's because few rv'ers use the propane oven. I just came back from a local rv show and was shocked to see almost all higher end rv's had cook top only (often induction) and a convection microwave. It's as if they expect to always be hooked up to 50 amp service.
I just don't think there is a big market for those of us that actually use the oven.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 01-25-2016, 09:51 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You might try appliances for apartments. They might fit.
2004 Excursion 4x4
Old 01-25-2016, 09:51 AM   #4
1974 Argosy 20
Kooskia , Idaho
And everything RV is built down to a price. The SOB RV factory buyers demand a lower price, and the appliance manufacturers make the product cheaper. Or, if demand is low, discontinue making it at all.
Old 01-25-2016, 10:15 AM   #5
Atlanta , Georgia
I have an original Magic Chef cook-top/oven with 4 burners from our '77 Overlander. It looks like it is in great shape. Is there a good enough market to sell it to fund other reno projects (we aren't doing an original restoration) or given the sounds of this thread, should we consider keeping it to put back in once we re-do the inside?
I'd consider shipping if you were interested TrekerBoy but I have no clue what it would cost for something this heavy.
jmelliott07 is offline   Reply With Quote
Old 01-25-2016, 10:22 AM   #6
cameront120's Avatar
1972 25' Tradewind
You could look into Marine appliances. Durable and usually a lot nicer to look at than their RV counterparts. For example:
Mediterranean Three Burner Gas Stove - Dickinson Marine | Dickinson Marine
FORCE 10 - Cooking Without Compromise - Products
North Vancouver, BC
Old 01-25-2016, 10:45 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Defender Marine (Marine Stoves / Ovens on Sale) is a reputable source for all things boat-related. And usually with better pricing than West Marine.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-25-2016, 11:27 AM   #8
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I have been lusting over the Dickinson Mediterranean stove for some time... They are proud of them, even when on "sale."
Dickinson Marine - Mediterranean 3 Burner Marine Propane Galley Range
Dickinson 00-MED3B Mediterranean 3 Burner Propane Galley Range
Old 01-25-2016, 11:47 AM   #9
1972 25' Tradewind
Keep in mind that both Dickinson and Force 10 are Canadian companies and with the Canadian Dollar being so low right now, you might be able to get a good deal on one of their products.
North Vancouver, BC
Old 01-25-2016, 12:19 PM   #10
2005 19' Safari
GLENDALE , AZ
We have an Origo 2-burner alcohol stove in our boat. All stainless steel, very sturdy and built to last; and it's less expensive than larger, gimballed marine stove/oven units. However, it's not quite as convenient as propane (kind of like big, blow-torch-like "sterno" burners on steroids), it requires carrying another different kind of liquid fuel (stove alcohol), and it sometimes emits a slight alcohol odor.
The stainless is beautiful, it's rugged, and alcohol stoves are safer than propane (alcohol is lighter than air, versus propane being heavier; thus, it's less prone to explosion, which is why alcohol stoves are used in boats instead of propane).
Note: Made in Sweden.
Old 01-25-2016, 01:04 PM   #11
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet use it a lot
We use our gas oven almost daily when on the road
dannydimitt is offline   Reply With Quote
Old 01-25-2016, 01:36 PM   #12
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Does anyone know how much the old gas range/ovens weighed, circa 1964? What would be the downside of installing an apartment size (20') gas range like this one... https://www.atgstores.com/ranges/dan...160125191219:s
It weighs 124#, more than double the new RV range/ovens.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 01-25-2016, 03:29 PM   #13
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
I would look at Smev cooktops. Very beautiful and they have a glass cover over eyelets when not in use. Comes in two and three burners, and burners and sink combos.
I have the three burner in my Globetrotter and it is great!Click image for larger version
Name:	Smev Cooktop.jpg
Name:	Smev Cooktop 2.jpg
montanablue is offline   Reply With Quote
Old 01-25-2016, 04:37 PM   #14
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Wallas Stovetops
Here are some high priced models from Wallas. I have no experience with them and I couldn't get my brother to spend the bucks when he was replacing his camper's appliances. They also can be used as a secondary heat source.
Wallas Heater | Boat | Stoves | Cooking Equipment | ScanMarineUSA.com | Wallas Heater | Boat | Stoves | Cooking Equipment | ScanMarineUSA.com
BoscoMN is offline   Reply With Quote
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 06:20 PM
1954 Safari serial number ranges yukionna 1954 Safari 0 10-08-2005 06:54 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 08:41 PM
