Old 04-16-2017, 11:02 PM   #113
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Originally Posted by trekerboy View Post
Unfortunately, no. We just don't use that burner. I suspect the spark just isn't big enough to ignite the gas (had a similar problem with my furnace at one point) but I can't seem to adjust it. Dometic said to take it to a dealer to fix it, but it's a lot of work to do that so we've just haven't been using that burner. Sort of a bummer.
Our is getting installed along with our other appliances while I'm traveling for family matters. I'm excited to check it our when I get home in a little over a week. Hope everything works.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 04-16-2017, 11:10 PM   #114
Caroyl's Avatar
1964 26' Overlander
Caroyl & Tim
WBCCI # 31088
Old 05-13-2017, 08:58 PM   #115
Caroyl's Avatar
1964 26' Overlander
Everything fires up and seems to work. Haven't finished the reno, so no cooking with it yet.
Caroyl & Tim
WBCCI # 31088
Old 05-13-2017, 09:04 PM   #116
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Love that stove! Should be an optional upgrade for all models
wulfraat is online now   Reply With Quote
Old 06-21-2017, 09:37 AM   #117
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Got our CU-434 installed recently - not plumbed, but I finished the housing for it. Countertops (2 cm thick manmade quartz) were dropped off yesterday as well.
Because neither my lower cabinet - nor their measurements - were perfectly square, I'll have to make minor adjustments to the cabinet using a sander or jigsaw... and they'll have to recut the piece between the oven and bulkhead wall. I'm confident we'll get the oven flush against the stone on both sides and mark this off the to-do list.
bredlo is offline   Reply With Quote
Old 06-21-2017, 06:36 PM   #118
wulfraat's Avatar
Sweet! Nicely done!
Old 06-22-2017, 07:13 AM   #119
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Wow, that looks great! Keep up the good work! The CU-434 looks great in that installation
trekerboy is offline   Reply With Quote
Old 06-22-2017, 07:28 AM   #120
Caroyl's Avatar
1964 26' Overlander
Love the quartz counters with the CU-434 Any idea what the counters weigh?
Caroyl & Tim
WBCCI # 31088
Old 06-22-2017, 07:39 AM   #121
1989 32' Excella
Sharon Springs , New York
If you like the stove and it's quality, maybe you could have a LPG technician check it
for safety and performance, then decide whether to replace/retain. Did that on my 1989 Excella and the unit checked out as almost brand new, so I kept it in place...
MAJORJDB is offline   Reply With Quote
Old 06-23-2017, 01:29 PM   #122
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the Dometic CU434 stove in both the 2014 Classic and the 2015 23D International Serenity. We also installed magnetic stainless steel side splash panels.
We retrofitted Vitrifrigo 12Vdc DanFoss freon compressor refrigerators in both trailers as well. As they are marine units, they both were slightly narrower than the ones they replaced and the one for Classic was enough shorter we made a custom storage space above it.
Name:	16-Finished stove install copy-Quick Preset_1080x1440.jpg
ID:	288035   Click image for larger version
Name:	18-Spice rack behind open burner lid copy-Quick Preset_1080x1440.jpg
Name:	28-Finished storage cabinet and new refrigerator copy-Quick Preset_1080x1440.jpg
ID:	288037   Click image for larger version
Name:	IMG_3267 copy-Quick Preset_1080x1440.jpg
Name:	IMG_3276 copy-Quick Preset_1080x1440.jpg
Old 06-23-2017, 03:46 PM   #123
bredlo's Avatar
1954 22' Safari
Good question. It's 2cm or about .75", around 8 feet long, minus the cutouts for the sink and oven. My guess is 110-120 pounds. We also have a dinette table in the same material, 46" by 32" and maybe 75 lbs. Far heavier than I would like, but hopefully I've balanced the layout well enough that it won't cause problems.
We'll use a Hensley Cub, so that should help also.
Old 08-14-2017, 12:00 AM   #124
4riveteers's Avatar
2016 27' Flying Cloud
SF Greater Bay Area , California
Before...
After...
Installed my wife's new SMEV range oven. She's happy, so I'm happy!
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 08-15-2017, 10:16 AM   #125
wulfraat's Avatar
Why do all replacement ranges look so cheap?
How did you fill the gap without installing a new counter top surface? My understanding is that the new unit is slightly narrower than the old one (but I could be wrong). did this turn out to be a drop in replacement with no modifications to the cabinetry necessary?
Could you provide a photo top-down of the new stove?
I bought a new trailer and I have the same crummy stove from airstream now. I'm looking to also replace like I did on my other trailer.
Looks great!
Old 08-15-2017, 01:27 PM   #126
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Nice. How's it work?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 06:20 PM
1954 Safari serial number ranges yukionna 1954 Safari 0 10-08-2005 06:54 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 08:41 PM
