Old 05-03-2016, 11:01 PM   #99
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Very nice installation of the stove. We start ours 9 May.
Old 05-04-2016, 08:17 AM   #100
Tincampers's Avatar
Sneedville , Tennessee
Originally Posted by wulfraat View Post
whoa that was a journey. but our install is complete
How has the range worked out for you? I want to replace ours, I don't like it at all. Do you have to stand on your head to light the oven? I see that each burner has its on pan holder rather than one for all 3. Has that been an issue? How is it to clean? I am so dissatisfied with ours I could write a book.
Tincampers is offline   Reply With Quote
Old 05-04-2016, 09:53 AM   #101
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Hey there - we just got the trailer back so our First trip with the stove will be this weekend. Overall the quality is much higher than our previous unit. It has 12 V electric start! No more crawling on the floor with a long match to light the oven pilot light.
Same for the burners - they are electric start as well and seem to have a reasonable range of high-med-low-simmer.
The oven also has a light and of course the glass door so you can monitor the food.
The fact that the glass lid sits flush with the counter is super nice as it provides more usable counter space, especially in a smaller galley like ours.
The little potholders / grills come off I believe so I suspect it will be pretty easy to clean like our last one.
The only downside so far is that the oven itself is a bit smaller than our last one. But overall - electric start, build quality, esthetics, integration with the counter top, light with glass door, etc... It was well worth it at $850 new from dometic compared to $500-600 for an Atwood stove.
Just make sure they ship it on a pallet! We had 3 stoves show up all smashed from shipping. They are delicate. 4th one came on a pallet
wulfraat is offline   Reply With Quote
Old 05-04-2016, 10:27 AM   #102
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How'd did it cook? Do the temperatures of the oven match the knob settings better?
No need for a pizza stone to keep the temperatures even?
If a recipe for baking states so many minutes did the item cook within that time or did you have to cook longer?
Kelvin
Old 05-04-2016, 10:31 AM   #103
wulfraat's Avatar
Have not cooked in it yet. Just got the trailer back. We are camping this weekend and I'll try to cook a pizza and report back
Old 05-04-2016, 08:41 PM   #104
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have the CU434 in my '15 Classic and I have used the oven about 20 times. (Yes, I bake...a LOT!) If you look in the oven, you'll see the burner arrangement is a straight line across the very back of the oven. The heating is NOT even. The further you place stuff toward the back of the oven, the higher likelihood it'll get done early. I do have a pizza stone in the bottom, though I don't know if that helps all that much. IMHO it needs some kind of a diffusing apparatus over the top of the flames to better distribute the heat and even out the temperature. Maybe then I wouldn't have to turn stuff so often! Other than that, the stove is a quantum improvement over the cheesy cook tops/stoves in the other trailers. It is really elegant....and the electric start for burners and oven works flawlessly. I am careful with the glass cover....I can only imagine what it would cost to replace it. Will be anxious to hear from others on their oven experiences.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-04-2016, 10:38 PM   #105
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
Following
amaier7771 is offline   Reply With Quote
Old 05-05-2016, 08:51 AM   #106
switz's Avatar
2014 31' Classic
Images: 8
I will provide the before, during and after photos of the CU434 stove installation and the Vitrifrigo DP150iL installation in our 23D starting 9 May.
Since I am traveling solo and this is a work trip, the decorative woman touches are not along, so it looks little barren.
Old 05-05-2016, 10:35 AM   #107
KJRitchie's Avatar
2008 25' Classic
From BAB's cooking performance report I don't feel replacing my stove/oven is justified. Also, my stove top cover has Corian on it and integrates with the counter top which is a more robust surface.
Kelvin
Old 08-11-2016, 05:35 PM   #108
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
An update and question on my Dometic CU-434...
I noticed today that the rear left burner will no longer light. There is a visible spark, and I can smell propane when I press in the knob, but no flames. I've tried to light it with the spark ignitor for up to five seconds with the gas knob pushed in, but it still wouldn't light. I am reluctant to let gas flow through the burner any longer than that for fear gas build up.
The other turn burners work fine.
Do I need a new burner? Or do I just need to adjust the ignitor for a different spark?
Any advice is appreciated.
trekerboy is offline   Reply With Quote
Old 08-11-2016, 08:04 PM   #109
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can smell gas but it is not lighting that says the gas is coming out someplace other than at the burner. Check the tubing leading to the burner to make sure it has not come apart from the burner. If you attempt any additional lighting, while looking for the leak, I would use a open flame such as a torch and be prepared to see it light beyond where you think it should light.
2004 Excursion 4x4
Old 08-13-2016, 07:49 PM   #110
trekerboy's Avatar
It works and flames come from the burner when I use a lighter. Doesn't spark + propane usually = flame? I'm confused. Is the spark not big enough or something? The spark is clearly visible, and the gas is definitely coming out of the burner...
Old 03-07-2017, 11:32 AM   #111
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Did you figure out the problem and solution for your burner issue yet??
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 03-08-2017, 06:01 PM   #112
trekerboy's Avatar
Unfortunately, no. We just don't use that burner. I suspect the spark just isn't big enough to ignite the gas (had a similar problem with my furnace at one point) but I can't seem to adjust it. Dometic said to take it to a dealer to fix it, but it's a lot of work to do that so we've just haven't been using that burner. Sort of a bummer.
Currently Active Users Viewing This Thread: 11 (1 members and 10 guests)
Plunderdog
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
1954 Safari serial number ranges yukionna 1954 Safari 0 10-08-2005 05:54 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
