Old 03-08-2016, 07:51 PM   #71
cameront120's Avatar
1972 25' Tradewind
Originally Posted by Starstream View Post
It's a 40 pg. document, but I do have the full, professional version of Acrobat which might allow me to pull out a few pages as long as it's not password protected. Otherwise, contact Dometic, tell them you wish to purchase this appliance and would like to know the specs. I wanted to know specifically if I could put a drawer under it for my heavy cookwear. They got back to me within the hour, with the PDF document attached to their reply.
You can easily attach the PDF to your post. If you scroll down below the post reply window, you'll see a button that reads "manage attachments' which will allow you to upload your PDF and attach it to your reply.
North Vancouver, BC
Old 03-09-2016, 06:13 AM   #72
Starstream's Avatar
Spring , Texas
Dometic CU-434 manual
I was concerned the file size might be too big for upload here, since I don't know what the cap is for memory on this site. But, here goes.
Instruction cu434.pdf
Starstream is offline   Reply With Quote
Old 03-09-2016, 06:25 AM   #73
Starstream's Avatar
Spring , Texas
Originally Posted by LaBigDogs View Post
Do you happen to know the price of just the cooktop with out the oven?
Dometic's US site only shows one stove on their website right now, and it's the model with the oven. But if it is the same appliance reviewed by Trailer Life/MotorHome magazines last year, it is actually made by SMEV. When I started looking for the oven model, I found all kinds of SMEV cook tops with 2 or 3 burners. Most of them were on sites from Australia, New Zealand or the UK.
Trekerboy found a different model of Dometic stove/oven called Moonlight 3 from a UK vender who was willing to ship to the US. If you can't find the cooktop you want here, look back a bit in the thread for that vender and see if they have something you like.
Old 03-09-2016, 07:37 AM   #74
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The pictures have shown a non-folding cover over the three burners. That could be an "opening the cover" issue in some model trailers with the taller overhead cabinets supporting the stove exhaust fan creating a smaller gap between the hinge point of the cover and the bottom of the exhaust fan. That is why for years there was the bi-fold cover over the burners.
One needs to take some measurements to be sure there is adequate space before ordering the stove.
Old 03-09-2016, 09:50 AM   #75
Starstream's Avatar
Spring , Texas
That's a good point, Switz. In our case, we're building new cabinetry because the original with it's paper laminate was getting a bit ratty. Dometic was nice enough to send me the manual when I asked for information, so we're constructing with this particular appliance in mind. For those who might need something a bit different than CU-434 with it's one-piece glass top, Atwood now has an electronic ignition range on it's website. Don't know if or when that model is available, but if PPL Motorhomes can now track down the Dometic, they might be able to look into Atwood's new stuff.
As for the SMEV cooktops, they seem to be fairly compact. I saw a 2-burner recently in a Freightliner class B motor home for sale at PPL in Houston. It was a little guy. I've received the impression that overseas RVers generally use small trailers and class B type motorhomes. So most of the stuff I've encountered online tends to be made for small spaces.
Old 03-09-2016, 04:11 PM   #76
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Trekerboy,
Who did you deal with at PPL? They are quoting me $1,027.05 + $204.05 shipping 😳 to California.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 03-10-2016, 11:57 AM   #77
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Originally Posted by Caroyl View Post
Trekerboy,
Christina at extension 161 was the one who helped me.
trekerboy is offline   Reply With Quote
Old 03-15-2016, 04:19 PM   #78
switz's Avatar
2014 31' Classic
Images: 8
We just ordered two Dometic/SMEV CU434 stainless steel oven/cooktop units from Bob Jones RV in South Houston (713-910-2949) for $899.99 each plus freight from their store to our installer in Paradise, TX. Lead time is two to three weeks.
The issue for us on the Dickinson was the large burner is in the middle of the back of the stove and would roast our spice racks located above the stove in both the Classic and the 23D. The CU434 has the one piece lift up glass lid that can funnel the burner heat away from the spice racks.
Old 03-16-2016, 09:46 AM   #79
trekerboy's Avatar
When I was checking for availability Bob Jones was one who said they could get it but the freight charge from their supplier to them and then them to me was an added $400. Glad you got a better deal!
Old 03-22-2016, 09:45 PM   #80
trekerboy's Avatar
We got our Dometic CU-434 today! It arrived slightly damaged but nothing I can't bend back in place myself. Considering what it took to find this unit I'm reluctant to send it back and ask for a new one on the account of a little bent metal.
Name:	ImageUploadedByAirstream Forums1458704484.948017.jpg
Here it is in the cut out that was previously occupied by our "vintage" (also known and old and broken) MagicChef unit. It is slightly shorter and slightly thinner than the old one, so some cabinet modifications are in line.
Old 03-24-2016, 09:26 AM   #81
Caroyl's Avatar
1964 26' Overlander
Please update us once installed and operational 😃
Caroyl & Tim
WBCCI # 31088
Old 03-24-2016, 10:56 AM   #82
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Do you need to put a pizza stone or tile in the oven to even out the heat like on other rv ovens?
Kelvin
Old 03-25-2016, 09:09 AM   #83
switz's Avatar
2014 31' Classic
Images: 8
Our CU434 stoves arrived at the Dallas Terminal on the 24th. They were supposed to go to their Ft Worth terminal for delivery, but there was a roof collapse at that Ft Worth terminal on the 23rd. So all the freight is still in Dallas. They expect delivery now to be Monday out of Dallas and we are hoping the stoves do not get damaged in all bedlam at that terminal.
Old 03-25-2016, 09:36 AM   #84
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
If I got one of these then I'd have to upgraded the ugly Ventline box stove vent. I kinda like the Corian stove top cover on my Classic. Could it be done on the CU434?
I hope someone will do a review on this oven including cooking/baking experience.
Kelvin
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
1954 Safari serial number ranges yukionna 1954 Safari 0 10-08-2005 05:54 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
