01-27-2008, 07:17 PM
#21
2007 23' International CCD
Lapeer
, Michigan
That's disappointing to hear since I am considering having Airstream retrofit my pantry with that microwave. Years ago we had a small low wattage combination microwave from Sears and the tip for popcorn was to put the bag on an upside down corelle plate. But I do think the wattage was 600. Though when you gotta have popcorn I could make it the old fashion way. I sure would like the convenience of quick heating with minimal clean-up from dirty pans and dishes often time, especially when there are no sewer hook-ups and we are watching the holding tank levels or winterized.
Did you see the alternative unit listed on that link of Dennis'?
Small Microwaves - Small Contoure Microwaves for boat, RV and home use - SailorSams.com
This Small Microwave Oven is brushed finish stainless steel on the outside, and white on the inside.
Shallow DepthMicrowave Oven model ICM-CM7060S
(cooking power): Cooking Power 700 watts.
Note: Input power required is greater than power output. Voltage: 120 Volts AC, 60 Hz (normal USA household power)Shipping Weight: 30 lbs.Outside Dimensions: 17" wide x 10-1/8" high x 12-3/4" deep
01-27-2008, 08:21 PM
#22
2021 27' Globetrotter
Saint Louis
, Missouri
Carol,
The unit is only 1/2" higher than the Tappan. The other dimensions are less than the Tappan. I'd think the extra 21% in power would make quite a difference. If it would fit, I'd opt for it.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
01-27-2008, 08:31 PM
#23
Lapeer
, Michigan
I like the finish too. Thanks for your input. Nice to know what is what beforehand. I am sure their mod is not inexpensive.
01-27-2008, 09:04 PM
#24
2015 27' Flying Cloud
Caledonia
, Michigan
This one is SMALL:
iwavecube Personal Microwave - Best of The Sharper Image
"The innovative Iwavecube personal microwave has all the electronic controls and safety features you expect, but it takes up less than a cubic foot of space. Plug it in anyplace that’s handy — work or home office; home gym; family room; nursery; wet bar; dorm room; work bench; pool house.everywhere! The quiet, super-energy-efficient iwavecube measures just 10″ x 10.5″ x 12″ and weighs only 12 lbs. Features a built-in carry handle and view-through door. Plugs into standard outlet."
01-27-2008, 10:48 PM
#25
2004 28' International CCD
Franklin
, Tennessee
You know, there are about 15 manufacturers making what is essentially the same sized product, makes one believe that a few years ago someone came up with a new smaller microwave transmitter and everybody jumped in to wrap a product around it. The Iwavecube above (thank you very much for this post, I plan on going to see it at one of the Sharper Image stores near here) and the Wavebox above may be the first two products of a coming avalanche of products (and falling prices) based on the new technology. In any event it's good to see that there appears to be a percieved market for yet smaller microwaves for us who need one. Thanks, Gerry
01-27-2008, 11:15 PM
#26
Yakima
Originally Posted by ROBERTSUNRUS
Hi, I find it facinateing that my plain jane, BVD, basic Safari comes standard with a stove top, oven, and microwave; And some of these high dollar, fancy, schmancy models come with a stove top and an oven or a microwave, but not all three.
ya...and it has a couch and soft walls just like a classic. And windows that don't leak...and MORE insulation,,,,I am liking that "B" model better everytime I look at one.
01-30-2008, 10:10 PM
#27
Franklin
, Tennessee
Originally Posted by Amsterdamer
This one is SMALL:
I went to a Sharper Image store today to check out this Microwave and it is a fine little machine. I'd rate it very good (we plugged it in and cooked some coffee) at jobs that will fit inside it. Certainly not a 1200 watt screamer, but for a small unit it is impressive. As I recall its rated 600 watts input, 330 watts cooking. Its very light, very small, very cute, and will fill the bill for our light microwaving needs. Gerry
01-30-2008, 11:08 PM
#28
Lapeer
, Michigan
Can you get anything other than a cup inside? What other things might it be useful for?
