Old 05-12-2011, 01:37 PM   #1
1994 34' Excella
Greenbank , Washington
Water in Stove Exhaust Vent
Good Morning to all!
After a heavy rain I noticed water had accumulated in the stove exhaust vent of our 1994 Excella.
It seems to have accumulated in the back (facing the stove) on top of the sheet metal ridge in there.
The exhaust vent is near the door, and is cracked on the plastic part, but I caulked around the outside of the vent - that didn't stop it.
This forum has some excellent, knowledgeable people, and I welcome your thoughts on this matter.
Any ideas?
Thanks in advance...
Airy is offline   Reply With Quote
Old 05-13-2011, 04:31 PM   #2
1994 34' Excella
Stove exhaust help!
Good Afternoon Everyone!
Thought I'd try again...
HOW IN THE WORLD DOES RAIN WATER ACCUMULATE IN THE EXHAUST FAN SPACE ABOVE THE STOVE????
Is there something I may have left open?
THANKS!
Old 05-13-2011, 05:08 PM   #3
richinny's Avatar
2011 34' Classic
could the leak be coming from the roof above the stove?
Ricky
Old 12-30-2014, 09:12 PM   #4
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
You are not the only one. See this thread:
http://www.airforums.com/forums/f456...eak-79828.html
Did you find any solutions?
lbdesign is offline   Reply With Quote
Old 01-05-2015, 12:31 PM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Leaking on Galley Side
Hi, I had the same issue of leaking on the kitchen side of my trailer, thought it was the vents (plumbing stack cover, refer and stove and roof vents) so I replaced all of them, she still had water coming in. Then we replaced and sealed all the exterior running light fixtures. Still had water coming in the vent areas... Then I spent a lot of time sealing each rivet on the entire trailer one by one with Captain Tolley's Creeping Crack Cure ...repeatedly...which definitely did help a lot but I still had water coming in the galley side. It ended up being the overlapping seam above the windows that runs the length of the trailer. It wasn't till I got frustrated and went out there in a rain storm and pulled all the upper interior panels off that I found what was truly the problem. I found it only has about a one inch overlap between the big side panel and the roof panel and when the wind and rain played wrong together it was blowing water up and over the entire side in areas, showing up as leaks in what I had first thought was the vents and windows. It was definitely tear worthy all that time I spent doing things to her only to go out the next time it rained to find more moisture infiltration but on the plus side now that I have repaired that long seam by applying Aluminium tinted gutter seal to the length of her she's a happy trailer now for a long time to come as every possible thing has been done to her now :-)
also I know by sitting in my trailer watching known problem areas it is absolutely amazing how much water can come in through a minute hole via either a rivet that sits a little to high or an air bubble in your sealant of choice. Take the time to look it over very closely even a gap 2 mils long lets a lot of water in. Also water can travel quite a distance before finding itself an exit so the one thing you do know is your leak is at level or above where you are seeing it come in from. Check the condition of your rear running lights to on the back quarter panel, as water can come in there and if your layout is similar to mine it is on that height level so that could be your source as well. Another possibility is some plumbing stack cover styles have a weep hole on the lower side that needs to be kept clear as well so water can escape the cover area, someone else that has that style may be better able to advise on what that style of plumbing stack cover looks like so you know if you need to be looking for weep holes on yours and if your stacks have the rubber gaskets under them, Andy at Inland RV says those are only supposed to last about three years before needing replacement, so there is another possible infiltration site for you to look at.
Oh and one other thing make sure you have the correct rivets everywhere. If you have any of the pop style ones water will travel through the hole in the middle of them. Swap those out for Olympics (or buck) if you find any on your trailer.
Captain Tolleys Creeping crack cure. Sitkaflex 221 and Aluminium tinted gutter seal are all your friends right now
Good Luck
thesignlady is offline   Reply With Quote
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 04:44 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 11:54 AM
Knob for kitchen exhaust vent fan chrischarles General Repair Forum 0 05-08-2011 07:53 PM
Stove Vent Motor Speed Control Road Geezer Stoves, Ovens & Microwaves 12 04-29-2011 03:12 PM
1954 Oven and stove vent?? AndrewM Stoves, Ovens & Microwaves 4 04-12-2011 07:46 AM
